| 1 |
/* RCSid $Id: lookup.h,v 2.11 2003/07/30 10:11:06 schorsch Exp $ */
| 2 |
| 3 |
* Header file for general associative table lookup routines
| 4 |
| 5 |
#ifndef _RAD_LOOKUP_H_
| 6 |
#define _RAD_LOOKUP_H_
| 7 |
| 8 |
#include <string.h> /* strcmp() */
| 9 |
| 10 |
#ifdef __cplusplus
| 11 |
extern "C" {
| 12 |
#endif
| 13 |
| 14 |
typedef void lut_free_t(void *p);
| 15 |
typedef unsigned long lut_hashf_t(void*);
| 16 |
typedef int lut_keycmpf_t(const void*, const void*);
| 17 |
| 18 |
typedef struct {
| 19 |
char *key; /* key name */
| 20 |
unsigned long hval; /* key hash value (for efficiency) */
| 21 |
char *data; /* pointer to client data */
| 22 |
} LUENT;
| 23 |
| 24 |
typedef struct {
| 25 |
lut_hashf_t *hashf; /* key hash function */
| 26 |
lut_keycmpf_t *keycmp; /* key comparison function */
| 27 |
lut_free_t *freek; /* free a key */
| 28 |
lut_free_t *freed; /* free the data */
| 29 |
int tsiz; /* current table size */
| 30 |
LUENT *tabl; /* table, if allocated */
| 31 |
int ndel; /* number of deleted entries */
| 32 |
} LUTAB;
| 33 |
| 34 |
| 35 |
| 36 |
* The lu_init routine is called to initialize a table. The number of
| 37 |
* elements passed is not a limiting factor, as a table can grow to
| 38 |
* any size permitted by memory. However, access will be more efficient
| 39 |
* if this number strikes a reasonable balance between default memory use
| 40 |
* and the expected (minimum) table size. The value returned is the
| 41 |
* actual allocated table size (or zero if there was insufficient memory).
| 42 |
| 43 |
* The hashf, keycmp, freek and freed member functions must be assigned
| 44 |
* separately. If the hash value is sufficient to guarantee equality
| 45 |
* between keys, then the keycmp pointer may be NULL. Otherwise, it
| 46 |
* should return 0 if the two passed keys match. If it is not necessary
| 47 |
* (or possible) to free the key and/or data values, then the freek and/or
| 48 |
* freed member functions may be NULL.
| 49 |
| 50 |
* It isn't fully necessary to call lu_init to initialize the LUTAB structure.
| 51 |
* If tsiz is 0, then the first call to lu_find will allocate a minimal table.
| 52 |
* The LU_SINIT macro provides a convenient static declaration for character
| 53 |
* string keys.
| 54 |
| 55 |
* The lu_find routine returns the entry corresponding to the given
| 56 |
* key. If the entry does not exist, the corresponding key field will
| 57 |
* be NULL. If the entry has been previously deleted but not yet freed,
| 58 |
* then only the data field will be NULL. It is the caller's
| 59 |
* responsibility to (allocate and) assign the key and data fields when
| 60 |
* creating a new entry. The only case where lu_find returns NULL is when
| 61 |
* the system has run out of memory.
| 62 |
| 63 |
* The lu_delete routine frees an entry's data (if any) by calling
| 64 |
* the freed member function, but does not free the key field. This
| 65 |
* will be freed later during (or instead of) table reallocation.
| 66 |
* It is therefore an error to reuse or do anything with the key
| 67 |
* field after calling lu_delete.
| 68 |
| 69 |
* The lu_doall routine loops through every filled table entry, calling
| 70 |
* the given function once on each entry. If a NULL pointer is passed
| 71 |
* for this function, then lu_doall simply returns the total number of
| 72 |
* active entries. Otherwise, it returns the sum of all the function
| 73 |
* evaluations.
| 74 |
| 75 |
* The lu_done routine calls the given free function once for each
| 76 |
* assigned table entry (i.e. each entry with an assigned key value).
| 77 |
* The user must define these routines to free the key and the data
| 78 |
* in the LU_TAB structure. The final action of lu_done is to free the
| 79 |
* allocated table itself.
| 80 |
| 81 |
| 82 |
typedef int lut_doallf_t(LUENT *p);
| 83 |
| 84 |
extern lut_keycmpf_t lu_strcmp;
| 85 |
extern int lu_init(LUTAB *tbl, int nel);
| 86 |
extern unsigned long lu_shash(void *s);
| 87 |
extern LUENT *lu_find(LUTAB *tbl, char *key);
| 88 |
extern void lu_delete(LUTAB *tbl, char *key);
| 89 |
extern int lu_doall(LUTAB *tbl, lut_doallf_t *f);
| 90 |
extern void lu_done(LUTAB *tbl);
| 91 |
| 92 |
#define LU_SINIT(fk,fd) {lu_shash,lu_strcmp,fk,fd,0,NULL,0}
| 93 |
| 94 |
#ifdef __cplusplus
| 95 |
| 96 |
#endif
| 97 |
#endif /* _RAD_LOOKUP_H_ */
| 98 |
