root/radiance/ray/src/common/lookup.h
Revision: 2.10
Committed: Mon Jul 14 22:23:59 2003 UTC (20 years, 9 months ago) by schorsch
1 /* RCSid $Id: lookup.h,v 2.9 2003/06/27 06:53:21 greg Exp $ */
2 /*
3 * Header file for general associative table lookup routines
4 */
5 #ifndef _RAD_LOOKUP_H_
6 #define _RAD_LOOKUP_H_
7
8 #include <string.h> /* strcmp() */
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 typedef struct {
15 char *key; /* key name */
16 unsigned long hval; /* key hash value (for efficiency) */
17 char *data; /* pointer to client data */
18 } LUENT;
19
20 typedef struct {
21 unsigned long (*hashf)(); /* key hash function */
22 int (*keycmp)(); /* key comparison function */
23 void (*freek)(); /* free a key */
24 void (*freed)(); /* free the data */
25 int tsiz; /* current table size */
26 LUENT *tabl; /* table, if allocated */
27 int ndel; /* number of deleted entries */
28 } LUTAB;
29
30 #undef strcmp
31 #define LU_SINIT(fk,fd) {lu_shash,strcmp,(void (*)())(fk),\
32 (void (*)())(fd),0,NULL,0}
33
34 /*
35 * The lu_init routine is called to initialize a table. The number of
36 * elements passed is not a limiting factor, as a table can grow to
37 * any size permitted by memory. However, access will be more efficient
38 * if this number strikes a reasonable balance between default memory use
39 * and the expected (minimum) table size. The value returned is the
40 * actual allocated table size (or zero if there was insufficient memory).
41 *
42 * The hashf, keycmp, freek and freed member functions must be assigned
43 * separately. If the hash value is sufficient to guarantee equality
44 * between keys, then the keycmp pointer may be NULL. Otherwise, it
45 * should return 0 if the two passed keys match. If it is not necessary
46 * (or possible) to free the key and/or data values, then the freek and/or
47 * freed member functions may be NULL.
48 *
49 * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
50 * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
51 * The LU_SINIT macro provides a convenient static declaration for character
52 * string keys.
53 *
54 * The lu_find routine returns the entry corresponding to the given
55 * key. If the entry does not exist, the corresponding key field will
56 * be NULL. If the entry has been previously deleted but not yet freed,
57 * then only the data field will be NULL. It is the caller's
58 * responsibility to (allocate and) assign the key and data fields when
59 * creating a new entry. The only case where lu_find returns NULL is when
60 * the system has run out of memory.
61 *
62 * The lu_delete routine frees an entry's data (if any) by calling
63 * the freed member function, but does not free the key field. This
64 * will be freed later during (or instead of) table reallocation.
65 * It is therefore an error to reuse or do anything with the key
66 * field after calling lu_delete.
67 *
68 * The lu_doall routine loops through every filled table entry, calling
69 * the given function once on each entry. If a NULL pointer is passed
70 * for this function, then lu_doall simply returns the total number of
71 * active entries. Otherwise, it returns the sum of all the function
72 * evaluations.
73 *
74 * The lu_done routine calls the given free function once for each
75 * assigned table entry (i.e. each entry with an assigned key value).
76 * The user must define these routines to free the key and the data
77 * in the LU_TAB structure. The final action of lu_done is to free the
78 * allocated table itself.
79 */
80
81 extern int lu_init(LUTAB *tbl, int nel);
82 extern unsigned long lu_shash(char *s);
83 extern LUENT *lu_find(LUTAB *tbl, char *key);
84 extern void lu_delete(LUTAB *tbl, char *key);
85 extern int lu_doall(LUTAB *tbl, int (*f)());
86 extern void lu_done(LUTAB *tbl);
87
88
89 #ifdef __cplusplus
90 }
91 #endif
92 #endif /* _RAD_LOOKUP_H_ */
93
