root/radiance/ray/src/common/lookup.h
Revision: 2.1
Committed: Wed Jul 6 15:14:16 1994 UTC (30 years, 11 months ago) by greg
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for general associative table lookup routines
7 */
8
9 typedef struct {
10 char *key; /* key name */
11 long hval; /* key hash value (for efficiency) */
12 char *data; /* pointer to client data */
13 } LUENT;
14
15 typedef struct {
16 long (*hashf)(); /* key hash function */
17 int (*keycmp)(); /* key comparison function */
18 void (*freek)(); /* free a key */
19 void (*freed)(); /* free the data */
20 int tsiz; /* current table size */
21 LUENT *tabl; /* table, if allocated */
22 int ndel; /* number of deleted entries */
23 } LUTAB;
24
25 #define LU_SINIT(fk,fd) {lu_shash,strcmp,(void (*)())(fk),\
26 (void (*)())(fd),0,NULL,0}
27
28 /*
29 * The lu_init routine is called to initialize a table. The number of
30 * elements passed is not a limiting factor, as a table can grow to
31 * any size permitted by memory. However, access will be more efficient
32 * if this number strikes a reasonable balance between default memory use
33 * and the expected (minimum) table size. The value returned is the
34 * actual allocated table size (or zero if there was insufficient memory).
35 *
36 * The hashf, keycmp, freek and freed member functions must be assigned
37 * separately. If the hash value is sufficient to guarantee equality
38 * between keys, then the keycmp pointer may be NULL. Otherwise, it
39 * should return 0 if the two passed keys match. If it is not necessary
40 * (or possible) to free the key and/or data values, then the freek and/or
41 * freed member functions may be NULL.
42 *
43 * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
44 * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
45 * The LU_SINIT macro provides a convenient static declaration for character
46 * string keys.
47 *
48 * The lu_find routine returns the entry corresponding to the given
49 * key. If the entry does not exist, the corresponding key field will
50 * be NULL. If the entry has been previously deleted but not yet freed,
51 * then only the data field will be NULL. It is the caller's
52 * responsibility to (allocate and) assign the key and data fields when
53 * creating a new entry. The only case where lu_find returns NULL is when
54 * the system has run out of memory.
55 *
56 * The lu_delete routine frees an entry's data (if any) by calling
57 * the freed member function, but does not free the key field. This
58 * will be freed later during (or instead of) table reallocation.
59 *
60 * The lu_done routine calls the given free function once for each
61 * assigned table entry (i.e. each entry with an assigned key value).
62 * The user must define these routines to free the key and the data
63 * in the LU_TAB structure. The final action of lu_done is to free the
64 * allocated table itself.
65 */
66
67 extern int lu_init();
68 extern LUENT *lu_find();
69 extern void lu_delete();
70 extern void lu_done();
71 extern long lu_shash();
72
73 extern int strcmp();
