--- ray/src/common/lookup.h 1997/09/17 14:46:48 2.3 +++ ray/src/common/lookup.h 1998/06/02 15:01:43 2.4 @@ -60,6 +60,12 @@ typedef struct { * It is therefore an error to reuse or do anything with the key * field after calling lu_delete. * + * The lu_doall routine loops through every filled table entry, calling + * the given function once on each entry. If a NULL pointer is passed + * for this function, then lu_doall simply returns the total number of + * active entries. Otherwise, it returns the sum of all the function + * evaluations. + * * The lu_done routine calls the given free function once for each * assigned table entry (i.e. each entry with an assigned key value). * The user must define these routines to free the key and the data @@ -70,6 +76,7 @@ typedef struct { extern int lu_init(); extern LUENT *lu_find(); extern void lu_delete(); +extern int lu_doall(); extern void lu_done(); extern long lu_shash();
