--- ray/src/common/lookup.h 2004/03/28 20:33:12 2.12 +++ ray/src/common/lookup.h 2004/05/25 06:30:46 2.13 @@ -1,4 +1,4 @@ -/* RCSid $Id: lookup.h,v 2.12 2004/03/28 20:33:12 schorsch Exp $ */ +/* RCSid $Id: lookup.h,v 2.13 2004/05/25 06:30:46 greg Exp $ */ /* * Header file for general associative table lookup routines */ @@ -79,14 +79,14 @@ typedef struct { * allocated table itself. */ -typedef int lut_doallf_t(LUENT *p); +typedef int lut_doallf_t(LUENT *e, void *p); extern lut_keycmpf_t lu_strcmp; extern int lu_init(LUTAB *tbl, int nel); extern unsigned long lu_shash(void *s); extern LUENT *lu_find(LUTAB *tbl, char *key); extern void lu_delete(LUTAB *tbl, char *key); -extern int lu_doall(LUTAB *tbl, lut_doallf_t *f); +extern int lu_doall(LUTAB *tbl, lut_doallf_t *f, void *p); extern void lu_done(LUTAB *tbl); #define LU_SINIT(fk,fd) {lu_shash,lu_strcmp,fk,fd,0,NULL,0}
