root/radiance/ray/src/common/lookup.h
Changes since 2.14: +7 -8 lines
Tue May 25 22:04:13 2004 UTC (20 years ago) by greg
Changes since 2.13: +8 -10 lines
Tue May 25 06:30:46 2004 UTC (20 years ago) by greg
Diff to previous 2.12
Added argument for client data to lu_doall()
Changes since 2.11: +12 -9 lines
Wed Jul 30 10:11:06 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.10: +10 -8 lines
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.8: +1 -4 lines
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 2.7: +13 -13 lines
*** empty log message ***
Changes since 2.6: +2 -57 lines
Changes since 2.5: +72 -5 lines
Wed Sep 2 18:42:11 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.4: +13 -13 lines
changed lookup routines to use unsigned long hash values
Tue Jun 2 15:01:43 1998 UTC (26 years ago) by gwlarson
Changes since 2.3: +7 -0 lines
added lu_doall() function to loop through table entries
Wed Sep 17 14:46:48 1997 UTC (26 years, 8 months ago) by gregl
undefined strcmp for systems (AIX) that define it as a macro
Thu Jul 7 14:02:31 1994 UTC (29 years, 11 months ago) by greg
added comment about reusing key field following lu_delete
Wed Jul 6 15:14:16 1994 UTC (29 years, 11 months ago) by greg
Diff to selected 2.12
