root/Development/ray/src/common/lookup.h
Revision: 2.14
Committed: Tue May 25 22:04:13 2004 UTC (21 years, 7 months ago) by greg
CVS Tags: rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Changes since 2.13: +8 -10 lines
# User Rev Content
1 greg 2.14 /* RCSid $Id: lookup.h,v 2.13 2004/05/25 06:30:46 greg Exp $ */
2 greg 2.1 /*
3     * Header file for general associative table lookup routines
4     */
5 schorsch 2.8 #ifndef _RAD_LOOKUP_H_
6     #define _RAD_LOOKUP_H_
7 schorsch 2.10
8 schorsch 2.8 #ifdef __cplusplus
9     extern "C" {
10     #endif
11 greg 2.6
12 schorsch 2.12 typedef void lut_free_t(void *p);
13 greg 2.14 typedef unsigned long lut_hashf_t(const void *);
14     typedef int lut_keycmpf_t(const void *, const void *);
15 schorsch 2.11
16 greg 2.1 typedef struct {
17 gwlarson 2.5 char *key; /* key name */
18     unsigned long hval; /* key hash value (for efficiency) */
19     char *data; /* pointer to client data */
20 greg 2.1 } LUENT;
21
22     typedef struct {
23 schorsch 2.12 lut_hashf_t *hashf; /* key hash function */
24     lut_keycmpf_t *keycmp; /* key comparison function */
25 schorsch 2.11 lut_free_t *freek; /* free a key */
26     lut_free_t *freed; /* free the data */
27 gwlarson 2.5 int tsiz; /* current table size */
28     LUENT *tabl; /* table, if allocated */
29     int ndel; /* number of deleted entries */
30 greg 2.1 } LUTAB;
31
32
33     /*
34     * The lu_init routine is called to initialize a table. The number of
35     * elements passed is not a limiting factor, as a table can grow to
36     * any size permitted by memory. However, access will be more efficient
37     * if this number strikes a reasonable balance between default memory use
38     * and the expected (minimum) table size. The value returned is the
39     * actual allocated table size (or zero if there was insufficient memory).
40     *
41     * The hashf, keycmp, freek and freed member functions must be assigned
42     * separately. If the hash value is sufficient to guarantee equality
43     * between keys, then the keycmp pointer may be NULL. Otherwise, it
44     * should return 0 if the two passed keys match. If it is not necessary
45     * (or possible) to free the key and/or data values, then the freek and/or
46     * freed member functions may be NULL.
47     *
48     * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
49     * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
50     * The LU_SINIT macro provides a convenient static declaration for character
51     * string keys.
52     *
53     * The lu_find routine returns the entry corresponding to the given
54     * key. If the entry does not exist, the corresponding key field will
55     * be NULL. If the entry has been previously deleted but not yet freed,
56     * then only the data field will be NULL. It is the caller's
57     * responsibility to (allocate and) assign the key and data fields when
58     * creating a new entry. The only case where lu_find returns NULL is when
59     * the system has run out of memory.
60     *
61     * The lu_delete routine frees an entry's data (if any) by calling
62     * the freed member function, but does not free the key field. This
63     * will be freed later during (or instead of) table reallocation.
64 greg 2.2 * It is therefore an error to reuse or do anything with the key
65     * field after calling lu_delete.
66 greg 2.1 *
67 gwlarson 2.4 * The lu_doall routine loops through every filled table entry, calling
68     * the given function once on each entry. If a NULL pointer is passed
69     * for this function, then lu_doall simply returns the total number of
70     * active entries. Otherwise, it returns the sum of all the function
71     * evaluations.
72     *
73 greg 2.1 * The lu_done routine calls the given free function once for each
74     * assigned table entry (i.e. each entry with an assigned key value).
75     * The user must define these routines to free the key and the data
76     * in the LU_TAB structure. The final action of lu_done is to free the
77     * allocated table itself.
78     */
79 greg 2.6
80 greg 2.14 typedef int lut_doallf_t(const LUENT *e, void *p);
81 schorsch 2.12
82     extern lut_keycmpf_t lu_strcmp;
83 greg 2.6 extern int lu_init(LUTAB *tbl, int nel);
84 greg 2.14 extern unsigned long lu_shash(const void *s);
85     extern LUENT *lu_find(LUTAB *tbl, const char *key);
86     extern void lu_delete(LUTAB *tbl, const char *key);
87     extern int lu_doall(const LUTAB *tbl, lut_doallf_t *f, void *p);
88 greg 2.6 extern void lu_done(LUTAB *tbl);
89
90 schorsch 2.12 #define LU_SINIT(fk,fd) {lu_shash,lu_strcmp,fk,fd,0,NULL,0}
91 schorsch 2.8
92     #ifdef __cplusplus
93     }
94 greg 2.6 #endif
95 schorsch 2.8 #endif /* _RAD_LOOKUP_H_ */
96
