--- ray/src/common/lookup.h 1997/09/17 14:46:48 2.3 +++ ray/src/common/lookup.h 2003/06/27 06:53:21 2.9 @@ -1,25 +1,27 @@ -/* Copyright (c) 1994 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: lookup.h,v 2.9 2003/06/27 06:53:21 greg Exp $ */ /* * Header file for general associative table lookup routines */ +#ifndef _RAD_LOOKUP_H_ +#define _RAD_LOOKUP_H_ +#ifdef __cplusplus +extern "C" { +#endif typedef struct { - char *key; /* key name */ - long hval; /* key hash value (for efficiency) */ - char *data; /* pointer to client data */ + char *key; /* key name */ + unsigned long hval; /* key hash value (for efficiency) */ + char *data; /* pointer to client data */ } LUENT; typedef struct { - long (*hashf)(); /* key hash function */ - int (*keycmp)(); /* key comparison function */ - void (*freek)(); /* free a key */ - void (*freed)(); /* free the data */ - int tsiz; /* current table size */ - LUENT *tabl; /* table, if allocated */ - int ndel; /* number of deleted entries */ + unsigned long (*hashf)(); /* key hash function */ + int (*keycmp)(); /* key comparison function */ + void (*freek)(); /* free a key */ + void (*freed)(); /* free the data */ + int tsiz; /* current table size */ + LUENT *tabl; /* table, if allocated */ + int ndel; /* number of deleted entries */ } LUTAB; #undef strcmp @@ -60,6 +62,12 @@ typedef struct { * It is therefore an error to reuse or do anything with the key * field after calling lu_delete. * + * The lu_doall routine loops through every filled table entry, calling + * the given function once on each entry. If a NULL pointer is passed + * for this function, then lu_doall simply returns the total number of + * active entries. Otherwise, it returns the sum of all the function + * evaluations. + * * The lu_done routine calls the given free function once for each * assigned table entry (i.e. each entry with an assigned key value). * The user must define these routines to free the key and the data @@ -67,10 +75,18 @@ typedef struct { * allocated table itself. */ -extern int lu_init(); -extern LUENT *lu_find(); -extern void lu_delete(); -extern void lu_done(); -extern long lu_shash(); +#include /* strcmp() */ -extern int strcmp(); +extern int lu_init(LUTAB *tbl, int nel); +extern unsigned long lu_shash(char *s); +extern LUENT *lu_find(LUTAB *tbl, char *key); +extern void lu_delete(LUTAB *tbl, char *key); +extern int lu_doall(LUTAB *tbl, int (*f)()); +extern void lu_done(LUTAB *tbl); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_LOOKUP_H_ */ +
