--- ray/src/common/lookup.h 2003/02/22 02:07:22 2.6 +++ ray/src/common/lookup.h 2004/05/25 22:04:13 2.14 @@ -1,65 +1,18 @@ -/* RCSid: $Id: lookup.h,v 2.6 2003/02/22 02:07:22 greg Exp $ */ +/* RCSid $Id: lookup.h,v 2.14 2004/05/25 22:04:13 greg Exp $ */ /* * Header file for general associative table lookup routines */ +#ifndef _RAD_LOOKUP_H_ +#define _RAD_LOOKUP_H_ -/* ==================================================================== - * The Radiance Software License, Version 1.0 - * - * Copyright (c) 1990 - 2002 The Regents of the University of California, - * through Lawrence Berkeley National Laboratory. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * - * 3. The end-user documentation included with the redistribution, - * if any, must include the following acknowledgment: - * "This product includes Radiance software - * (http://radsite.lbl.gov/) - * developed by the Lawrence Berkeley National Laboratory - * (http://www.lbl.gov/)." - * Alternately, this acknowledgment may appear in the software itself, - * if and wherever such third-party acknowledgments normally appear. - * - * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" - * and "The Regents of the University of California" must - * not be used to endorse or promote products derived from this - * software without prior written permission. For written - * permission, please contact radiance@radsite.lbl.gov. - * - * 5. Products derived from this software may not be called "Radiance", - * nor may "Radiance" appear in their name, without prior written - * permission of Lawrence Berkeley National Laboratory. - * - * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED - * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR - * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF - * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT - * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - * ==================================================================== - * - * This software consists of voluntary contributions made by many - * individuals on behalf of Lawrence Berkeley National Laboratory. For more - * information on Lawrence Berkeley National Laboratory, please see - * . - */ +#ifdef __cplusplus +extern "C" { +#endif +typedef void lut_free_t(void *p); +typedef unsigned long lut_hashf_t(const void *); +typedef int lut_keycmpf_t(const void *, const void *); + typedef struct { char *key; /* key name */ unsigned long hval; /* key hash value (for efficiency) */ @@ -67,18 +20,15 @@ typedef struct { } LUENT; typedef struct { - unsigned long (*hashf)(); /* key hash function */ - int (*keycmp)(); /* key comparison function */ - void (*freek)(); /* free a key */ - void (*freed)(); /* free the data */ + lut_hashf_t *hashf; /* key hash function */ + lut_keycmpf_t *keycmp; /* key comparison function */ + lut_free_t *freek; /* free a key */ + lut_free_t *freed; /* free the data */ int tsiz; /* current table size */ LUENT *tabl; /* table, if allocated */ int ndel; /* number of deleted entries */ } LUTAB; -#undef strcmp -#define LU_SINIT(fk,fd) {lu_shash,strcmp,(void (*)())(fk),\ - (void (*)())(fd),0,NULL,0} /* * The lu_init routine is called to initialize a table. The number of @@ -127,24 +77,20 @@ typedef struct { * allocated table itself. */ -extern int strcmp(); +typedef int lut_doallf_t(const LUENT *e, void *p); -#ifdef NOPROTO - -extern int lu_init(); -extern LUENT *lu_find(); -extern void lu_delete(); -extern int lu_doall(); -extern void lu_done(); -extern unsigned long lu_shash(); - -#else - +extern lut_keycmpf_t lu_strcmp; extern int lu_init(LUTAB *tbl, int nel); -extern unsigned long lu_shash(char *s); -extern LUENT *lu_find(LUTAB *tbl, char *key); -extern void lu_delete(LUTAB *tbl, char *key); -extern int lu_doall(LUTAB *tbl, int (*f)()); +extern unsigned long lu_shash(const void *s); +extern LUENT *lu_find(LUTAB *tbl, const char *key); +extern void lu_delete(LUTAB *tbl, const char *key); +extern int lu_doall(const LUTAB *tbl, lut_doallf_t *f, void *p); extern void lu_done(LUTAB *tbl); +#define LU_SINIT(fk,fd) {lu_shash,lu_strcmp,fk,fd,0,NULL,0} + +#ifdef __cplusplus +} #endif +#endif /* _RAD_LOOKUP_H_ */ +
