--- ray/src/common/lookup.h 1994/07/06 15:14:16 2.1 +++ ray/src/common/lookup.h 1994/07/07 14:02:31 2.2 @@ -56,6 +56,8 @@ typedef struct { * The lu_delete routine frees an entry's data (if any) by calling * the freed member function, but does not free the key field. This * will be freed later during (or instead of) table reallocation. + * It is therefore an error to reuse or do anything with the key + * field after calling lu_delete. * * The lu_done routine calls the given free function once for each * assigned table entry (i.e. each entry with an assigned key value).
