--- ray/src/common/lookup.h 2003/02/22 02:07:22 2.6
+++ ray/src/common/lookup.h 2003/06/06 16:38:47 2.8
@@ -1,65 +1,16 @@
-/* RCSid: $Id: lookup.h,v 2.6 2003/02/22 02:07:22 greg Exp $ */
+/* RCSid $Id: lookup.h,v 2.8 2003/06/06 16:38:47 schorsch Exp $ */
* Header file for general associative table lookup routines
+#ifndef _RAD_LOOKUP_H_
+#define _RAD_LOOKUP_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
+#include "copyright.h"
typedef struct {
char *key; /* key name */
unsigned long hval; /* key hash value (for efficiency) */
@@ -127,19 +78,8 @@ typedef struct {
* allocated table itself.
-extern int strcmp();
+#include /* strcmp() */
-#ifdef NOPROTO
-extern int lu_init();
-extern LUENT *lu_find();
-extern void lu_delete();
-extern int lu_doall();
-extern void lu_done();
-extern unsigned long lu_shash();
-#else
extern int lu_init(LUTAB *tbl, int nel);
extern unsigned long lu_shash(char *s);
extern LUENT *lu_find(LUTAB *tbl, char *key);
@@ -147,4 +87,9 @@ extern void lu_delete(LUTAB *tbl, char *key);
extern int lu_doall(LUTAB *tbl, int (*f)());
extern void lu_done(LUTAB *tbl);
+#ifdef __cplusplus
#endif
+#endif /* _RAD_LOOKUP_H_ */
