root/Development/ray/src/common/lookup.h
Revision: 2.6
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.5: +72 -5 lines
1 /* RCSid: $Id$ */
2 /*
3 * Header file for general associative table lookup routines
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 typedef struct {
64 char *key; /* key name */
65 unsigned long hval; /* key hash value (for efficiency) */
66 char *data; /* pointer to client data */
67 } LUENT;
68
69 typedef struct {
70 unsigned long (*hashf)(); /* key hash function */
71 int (*keycmp)(); /* key comparison function */
72 void (*freek)(); /* free a key */
73 void (*freed)(); /* free the data */
74 int tsiz; /* current table size */
75 LUENT *tabl; /* table, if allocated */
76 int ndel; /* number of deleted entries */
77 } LUTAB;
78
79 #undef strcmp
80 #define LU_SINIT(fk,fd) {lu_shash,strcmp,(void (*)())(fk),\
81 (void (*)())(fd),0,NULL,0}
82
83 /*
84 * The lu_init routine is called to initialize a table. The number of
85 * elements passed is not a limiting factor, as a table can grow to
86 * any size permitted by memory. However, access will be more efficient
87 * if this number strikes a reasonable balance between default memory use
88 * and the expected (minimum) table size. The value returned is the
89 * actual allocated table size (or zero if there was insufficient memory).
90 *
91 * The hashf, keycmp, freek and freed member functions must be assigned
92 * separately. If the hash value is sufficient to guarantee equality
93 * between keys, then the keycmp pointer may be NULL. Otherwise, it
94 * should return 0 if the two passed keys match. If it is not necessary
95 * (or possible) to free the key and/or data values, then the freek and/or
96 * freed member functions may be NULL.
97 *
98 * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
99 * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
100 * The LU_SINIT macro provides a convenient static declaration for character
101 * string keys.
102 *
103 * The lu_find routine returns the entry corresponding to the given
104 * key. If the entry does not exist, the corresponding key field will
105 * be NULL. If the entry has been previously deleted but not yet freed,
106 * then only the data field will be NULL. It is the caller's
107 * responsibility to (allocate and) assign the key and data fields when
108 * creating a new entry. The only case where lu_find returns NULL is when
109 * the system has run out of memory.
110 *
111 * The lu_delete routine frees an entry's data (if any) by calling
112 * the freed member function, but does not free the key field. This
113 * will be freed later during (or instead of) table reallocation.
114 * It is therefore an error to reuse or do anything with the key
115 * field after calling lu_delete.
116 *
117 * The lu_doall routine loops through every filled table entry, calling
118 * the given function once on each entry. If a NULL pointer is passed
119 * for this function, then lu_doall simply returns the total number of
120 * active entries. Otherwise, it returns the sum of all the function
121 * evaluations.
122 *
123 * The lu_done routine calls the given free function once for each
124 * assigned table entry (i.e. each entry with an assigned key value).
125 * The user must define these routines to free the key and the data
126 * in the LU_TAB structure. The final action of lu_done is to free the
127 * allocated table itself.
128 */
129
130 extern int strcmp();
131
132 #ifdef NOPROTO
133
134 extern int lu_init();
135 extern LUENT *lu_find();
136 extern void lu_delete();
137 extern int lu_doall();
138 extern void lu_done();
139 extern unsigned long lu_shash();
140
141 #else
142
143 extern int lu_init(LUTAB *tbl, int nel);
144 extern unsigned long lu_shash(char *s);
145 extern LUENT *lu_find(LUTAB *tbl, char *key);
146 extern void lu_delete(LUTAB *tbl, char *key);
147 extern int lu_doall(LUTAB *tbl, int (*f)());
148 extern void lu_done(LUTAB *tbl);
149
150 #endif
