root/radiance/ray/src/common/lookup.c
Revision: 2.16
Committed: Wed Jun 7 17:52:03 2006 UTC (17 years, 10 months ago) by schorsch
CVS Tags: rad4R0, rad3R8, rad3R9
Changes since 2.15: +2 -1 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 schorsch 2.16 static const char RCSid[] = "$Id: lookup.c,v 2.15 2004/05/25 22:04:13 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Table lookup routines
6     */
7 greg 2.6
8 greg 2.1 #include <stdio.h>
9 greg 2.6 #include <stdlib.h>
10 schorsch 2.16 #include <string.h>
11 schorsch 2.9
12 greg 2.1 #include "lookup.h"
13
14 schorsch 2.13 extern int
15     lu_strcmp(
16     const void *s1,
17     const void *s2
18     )
19     {
20     return strcmp((const char*)s1,(const char*)s2);
21     }
22 greg 2.1
23 schorsch 2.13 extern int
24     lu_init( /* initialize tbl for at least nel elements */
25     register LUTAB *tbl,
26     int nel
27     )
28 greg 2.1 {
29     static int hsiztab[] = {
30 gregl 2.3 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
31     32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
32     4194301, 8388593, 0
33 greg 2.1 };
34     register int *hsp;
35
36     nel += nel>>1; /* 66% occupancy */
37     for (hsp = hsiztab; *hsp; hsp++)
38     if (*hsp > nel)
39     break;
40     if (!(tbl->tsiz = *hsp))
41     tbl->tsiz = nel*2 + 1; /* not always prime */
42     tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
43     if (tbl->tabl == NULL)
44     tbl->tsiz = 0;
45     tbl->ndel = 0;
46     return(tbl->tsiz);
47     }
48
49
50 schorsch 2.13 extern unsigned long
51     lu_shash( /* hash a nul-terminated string */
52 greg 2.15 const void *s
53 schorsch 2.13 )
54 greg 2.1 {
55 gregl 2.3 static unsigned char shuffle[256] = {
56     0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
57     191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
58     126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
59     61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
60     252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
61     187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
62     122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
63     57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
64     248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
65     183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
66     118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
67     53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
68     244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
69     179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
70     114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
71     49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
72     240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
73     175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
74     110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
75     45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
76     236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
77     171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
78     106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
79     41, 198, 99
80     };
81 greg 2.1 register int i = 0;
82 gwlarson 2.5 register unsigned long h = 0;
83 greg 2.15 register unsigned const char *t = (unsigned const char *)s;
84 greg 2.1
85 gregl 2.3 while (*t)
86 gwlarson 2.5 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
87 gregl 2.3
88 greg 2.1 return(h);
89     }
90
91
92 schorsch 2.13 extern LUENT *
93     lu_find( /* find a table entry */
94     register LUTAB *tbl,
95 greg 2.15 const char *key
96 schorsch 2.13 )
97 greg 2.1 {
98 gwlarson 2.5 unsigned long hval;
99 gregl 2.3 int i, n;
100 greg 2.1 register int ndx;
101 gregl 2.3 register LUENT *le;
102 greg 2.1 /* look up object */
103 gwlarson 2.5 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
104     return(NULL);
105 greg 2.1 hval = (*tbl->hashf)(key);
106     tryagain:
107 gregl 2.3 ndx = hval % tbl->tsiz;
108     for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
109 gwlarson 2.5 le = &tbl->tabl[ndx];
110 gregl 2.3 if (le->key == NULL) {
111     le->hval = hval;
112     return(le);
113 greg 2.1 }
114 gregl 2.3 if (le->hval == hval &&
115     (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
116     return(le);
117     }
118 gwlarson 2.5 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
119 gregl 2.3 ndx = ndx % tbl->tsiz;
120 greg 2.1 }
121     /* table is full, reallocate */
122 gregl 2.3 le = tbl->tabl;
123 greg 2.1 ndx = tbl->tsiz;
124     i = tbl->ndel;
125 greg 2.2 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
126 gregl 2.3 tbl->tabl = le;
127 greg 2.1 tbl->tsiz = ndx;
128     tbl->ndel = i;
129     return(NULL);
130     }
131     /*
132     * The following code may fail if the user has reclaimed many
133     * deleted entries and the system runs out of memory in a
134     * recursive call to lu_find().
135     */
136     while (ndx--)
137 schorsch 2.10 if (le[ndx].key != NULL) {
138 gregl 2.3 if (le[ndx].data != NULL)
139 schorsch 2.10 *lu_find(tbl,le[ndx].key) = le[ndx];
140 greg 2.1 else if (tbl->freek != NULL)
141 gregl 2.3 (*tbl->freek)(le[ndx].key);
142 schorsch 2.10 }
143 greg 2.6 free((void *)le);
144 greg 2.1 goto tryagain; /* should happen only once! */
145     }
146
147
148 schorsch 2.13 extern void
149     lu_delete( /* delete a table entry */
150     register LUTAB *tbl,
151 greg 2.15 const char *key
152 schorsch 2.13 )
153 greg 2.1 {
154     register LUENT *le;
155
156     if ((le = lu_find(tbl, key)) == NULL)
157     return;
158     if (le->key == NULL || le->data == NULL)
159     return;
160     if (tbl->freed != NULL)
161     (*tbl->freed)(le->data);
162     le->data = NULL;
163     tbl->ndel++;
164     }
165
166
167 schorsch 2.13 extern int
168     lu_doall( /* loop through all valid table entries */
169 greg 2.15 register const LUTAB *tbl,
170     //int (*f)(const LUENT *)
171 greg 2.14 lut_doallf_t *f,
172     void *p
173 schorsch 2.13 )
174 gwlarson 2.4 {
175     int rval = 0;
176 greg 2.15 register const LUENT *tp;
177 gwlarson 2.4
178     for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
179 schorsch 2.10 if (tp->data != NULL) {
180 greg 2.14 if (f != NULL) {
181     int r = (*f)(tp, p);
182     if (r < 0)
183     return(-1);
184     rval += r;
185     } else
186 gwlarson 2.4 rval++;
187 schorsch 2.10 }
188 gwlarson 2.4 return(rval);
189     }
190
191
192 schorsch 2.13 extern void
193     lu_done( /* free table and contents */
194     register LUTAB *tbl
195     )
196 greg 2.1 {
197     register LUENT *tp;
198
199     if (!tbl->tsiz)
200     return;
201     for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
202     if (tp->key != NULL) {
203     if (tbl->freek != NULL)
204     (*tbl->freek)(tp->key);
205     if (tp->data != NULL && tbl->freed != NULL)
206     (*tbl->freed)(tp->data);
207     }
208 greg 2.6 free((void *)tbl->tabl);
209 greg 2.1 tbl->tabl = NULL;
210     tbl->tsiz = 0;
211     tbl->ndel = 0;
212     }
