root/radiance/ray/src/common/lookup.c
Revision: 2.9
Committed: Mon Jun 30 14:59:11 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.8: +4 -2 lines
2 static const char RCSid[] = "$Id: lookup.c,v 2.8 2003/05/13 17:58:32 greg Exp $";
5 * Table lookup routines
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <string.h>
13
14 #include "lookup.h"
15
16 #ifdef NOSTRUCTASS
17 #define copystruct(d,s) memcpy((void *)(d),(void *)(s),sizeof(*(d)))
18 #else
19 #define copystruct(d,s) (*(d) = *(s))
20 #endif
21
22
23 int
24 lu_init(tbl, nel) /* initialize tbl for at least nel elements */
25 register LUTAB *tbl;
26 int nel;
27 {
28 static int hsiztab[] = {
29 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
30 32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
31 4194301, 8388593, 0
32 };
33 register int *hsp;
34
35 nel += nel>>1; /* 66% occupancy */
36 for (hsp = hsiztab; *hsp; hsp++)
37 if (*hsp > nel)
38 break;
39 if (!(tbl->tsiz = *hsp))
40 tbl->tsiz = nel*2 + 1; /* not always prime */
41 tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
42 if (tbl->tabl == NULL)
43 tbl->tsiz = 0;
44 tbl->ndel = 0;
45 return(tbl->tsiz);
46 }
47
48
49 unsigned long
50 lu_shash(s) /* hash a nul-terminated string */
51 char *s;
52 {
53 static unsigned char shuffle[256] = {
54 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
55 191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
56 126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
57 61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
58 252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
59 187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
60 122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
61 57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
62 248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
63 183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
64 118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
65 53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
66 244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
67 179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
68 114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
69 49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
70 240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
71 175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
72 110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
73 45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
74 236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
75 171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
76 106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
77 41, 198, 99
78 };
79 register int i = 0;
80 register unsigned long h = 0;
81 register unsigned char *t = (unsigned char *)s;
82
83 while (*t)
84 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
85
86 return(h);
87 }
88
89
90 LUENT *
91 lu_find(tbl, key) /* find a table entry */
92 register LUTAB *tbl;
93 char *key;
94 {
95 unsigned long hval;
96 int i, n;
97 register int ndx;
98 register LUENT *le;
99 /* look up object */
100 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
101 return(NULL);
102 hval = (*tbl->hashf)(key);
103 tryagain:
104 ndx = hval % tbl->tsiz;
105 for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
106 le = &tbl->tabl[ndx];
107 if (le->key == NULL) {
108 le->hval = hval;
109 return(le);
110 }
111 if (le->hval == hval &&
112 (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
113 return(le);
114 }
115 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
116 ndx = ndx % tbl->tsiz;
117 }
118 /* table is full, reallocate */
119 le = tbl->tabl;
120 ndx = tbl->tsiz;
121 i = tbl->ndel;
122 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
123 tbl->tabl = le;
124 tbl->tsiz = ndx;
125 tbl->ndel = i;
126 return(NULL);
127 }
128 /*
129 * The following code may fail if the user has reclaimed many
130 * deleted entries and the system runs out of memory in a
131 * recursive call to lu_find().
132 */
133 while (ndx--)
134 if (le[ndx].key != NULL)
135 if (le[ndx].data != NULL)
136 copystruct(lu_find(tbl,le[ndx].key), &le[ndx]);
137 else if (tbl->freek != NULL)
138 (*tbl->freek)(le[ndx].key);
139 free((void *)le);
140 goto tryagain; /* should happen only once! */
141 }
142
143
144 void
145 lu_delete(tbl, key) /* delete a table entry */
146 register LUTAB *tbl;
147 char *key;
148 {
149 register LUENT *le;
150
151 if ((le = lu_find(tbl, key)) == NULL)
152 return;
153 if (le->key == NULL || le->data == NULL)
154 return;
155 if (tbl->freed != NULL)
156 (*tbl->freed)(le->data);
157 le->data = NULL;
158 tbl->ndel++;
159 }
160
161
162 int
163 lu_doall(tbl, f) /* loop through all valid table entries */
164 register LUTAB *tbl;
165 int (*f)();
166 {
167 int rval = 0;
168 register LUENT *tp;
169
170 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
171 if (tp->data != NULL)
172 if (f != NULL)
173 rval += (*f)(tp);
174 else
175 rval++;
176 return(rval);
177 }
178
179
180 void
181 lu_done(tbl) /* free table and contents */
182 register LUTAB *tbl;
183 {
184 register LUENT *tp;
185
186 if (!tbl->tsiz)
187 return;
188 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
189 if (tp->key != NULL) {
190 if (tbl->freek != NULL)
191 (*tbl->freek)(tp->key);
192 if (tp->data != NULL && tbl->freed != NULL)
193 (*tbl->freed)(tp->data);
194 }
195 free((void *)tbl->tabl);
196 tbl->tabl = NULL;
197 tbl->tsiz = 0;
198 tbl->ndel = 0;
199 }
