root/Development/ray/src/common/lookup.c
Revision: 2.5
Committed: Thu Sep 3 14:22:23 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.4: +16 -15 lines
changed lookup routines to use unsigned long hash values
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Table lookup routines
9 */
10
11 #include <stdio.h>
12 #include "lookup.h"
13
14 #ifdef NOSTRUCTASS
15 #define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d)))
16 #else
17 #define copystruct(d,s) (*(d) = *(s))
18 #endif
19
20 #define MEM_PTR char *
21
22 extern MEM_PTR calloc();
23
24
25 int
26 lu_init(tbl, nel) /* initialize tbl for at least nel elements */
27 register LUTAB *tbl;
28 int nel;
29 {
30 static int hsiztab[] = {
31 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
32 32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
33 4194301, 8388593, 0
34 };
35 register int *hsp;
36
37 nel += nel>>1; /* 66% occupancy */
38 for (hsp = hsiztab; *hsp; hsp++)
39 if (*hsp > nel)
40 break;
41 if (!(tbl->tsiz = *hsp))
42 tbl->tsiz = nel*2 + 1; /* not always prime */
43 tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
44 if (tbl->tabl == NULL)
45 tbl->tsiz = 0;
46 tbl->ndel = 0;
47 return(tbl->tsiz);
48 }
49
50
51 unsigned long
52 lu_shash(s) /* hash a nul-terminated string */
53 char *s;
54 {
55 static unsigned char shuffle[256] = {
56 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
57 191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
58 126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
59 61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
60 252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
61 187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
62 122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
63 57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
64 248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
65 183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
66 118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
67 53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
68 244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
69 179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
70 114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
71 49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
72 240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
73 175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
74 110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
75 45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
76 236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
77 171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
78 106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
79 41, 198, 99
80 };
81 register int i = 0;
82 register unsigned long h = 0;
83 register unsigned char *t = (unsigned char *)s;
84
85 while (*t)
86 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
87
88 return(h);
89 }
90
91
92 LUENT *
93 lu_find(tbl, key) /* find a table entry */
94 register LUTAB *tbl;
95 char *key;
96 {
97 unsigned long hval;
98 int i, n;
99 register int ndx;
100 register LUENT *le;
101 /* look up object */
102 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
103 return(NULL);
104 hval = (*tbl->hashf)(key);
105 tryagain:
106 ndx = hval % tbl->tsiz;
107 for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
108 le = &tbl->tabl[ndx];
109 if (le->key == NULL) {
110 le->hval = hval;
111 return(le);
112 }
113 if (le->hval == hval &&
114 (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
115 return(le);
116 }
117 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
118 ndx = ndx % tbl->tsiz;
119 }
120 /* table is full, reallocate */
121 le = tbl->tabl;
122 ndx = tbl->tsiz;
123 i = tbl->ndel;
124 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
125 tbl->tabl = le;
126 tbl->tsiz = ndx;
127 tbl->ndel = i;
128 return(NULL);
129 }
130 /*
131 * The following code may fail if the user has reclaimed many
132 * deleted entries and the system runs out of memory in a
133 * recursive call to lu_find().
134 */
135 while (ndx--)
136 if (le[ndx].key != NULL)
137 if (le[ndx].data != NULL)
138 copystruct(lu_find(tbl,le[ndx].key), &le[ndx]);
139 else if (tbl->freek != NULL)
140 (*tbl->freek)(le[ndx].key);
141 free((MEM_PTR)le);
142 goto tryagain; /* should happen only once! */
143 }
144
145
146 void
147 lu_delete(tbl, key) /* delete a table entry */
148 register LUTAB *tbl;
149 char *key;
150 {
151 register LUENT *le;
152
153 if ((le = lu_find(tbl, key)) == NULL)
154 return;
155 if (le->key == NULL || le->data == NULL)
156 return;
157 if (tbl->freed != NULL)
158 (*tbl->freed)(le->data);
159 le->data = NULL;
160 tbl->ndel++;
161 }
162
163
164 int
165 lu_doall(tbl, f) /* loop through all valid table entries */
166 register LUTAB *tbl;
167 int (*f)();
168 {
169 int rval = 0;
170 register LUENT *tp;
171
172 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
173 if (tp->data != NULL)
174 if (f != NULL)
175 rval += (*f)(tp);
176 else
177 rval++;
178 return(rval);
179 }
180
181
182 void
183 lu_done(tbl) /* free table and contents */
184 register LUTAB *tbl;
185 {
186 register LUENT *tp;
187
188 if (!tbl->tsiz)
189 return;
190 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
191 if (tp->key != NULL) {
192 if (tbl->freek != NULL)
193 (*tbl->freek)(tp->key);
194 if (tp->data != NULL && tbl->freed != NULL)
195 (*tbl->freed)(tp->data);
196 }
197 free((MEM_PTR)tbl->tabl);
198 tbl->tabl = NULL;
199 tbl->tsiz = 0;
200 tbl->ndel = 0;
201 }
