--- ray/src/common/lookup.c 1997/12/03 10:59:30 2.3
+++ ray/src/common/lookup.c 2003/02/22 02:07:22 2.6
@@ -1,21 +1,78 @@
-/* Copyright (c) 1997 Silicon Graphics, Inc. */
#ifndef lint
-static char SCCSid[] = "$SunId$ SGI";
+static const char RCSid[] = "$Id: lookup.c,v 2.6 2003/02/22 02:07:22 greg Exp $";
#endif
* Table lookup routines
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
#include
+#include
#include "lookup.h"
-#define MEM_PTR char *
+#ifdef NOSTRUCTASS
+#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d)))
+#else
+#define copystruct(d,s) (*(d) = *(s))
+#endif
-extern MEM_PTR calloc();
int
lu_init(tbl, nel) /* initialize tbl for at least nel elements */
register LUTAB *tbl;
@@ -42,7 +99,7 @@ int nel;
-long
+unsigned long
lu_shash(s) /* hash a nul-terminated string */
char *s;
@@ -73,11 +130,11 @@ char *s;
41, 198, 99
register int i = 0;
- register long h = 0;
+ register unsigned long h = 0;
register unsigned char *t = (unsigned char *)s;
while (*t)
- h ^= (long)shuffle[*t++] << ((i+=11) & 0xf);
+ h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
return(h);
@@ -88,18 +145,18 @@ lu_find(tbl, key) /* find a table entry */
char *key;
- long hval;
+ unsigned long hval;
int i, n;
register int ndx;
register LUENT *le;
/* look up object */
- if (tbl->tsiz == 0)
- lu_init(tbl, 1);
+ if (tbl->tsiz == 0 && !lu_init(tbl, 1))
+ return(NULL);
hval = (*tbl->hashf)(key);
tryagain:
ndx = hval % tbl->tsiz;
- le = &tbl->tabl[ndx];
for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
+ le = &tbl->tabl[ndx];
if (le->key == NULL) {
le->hval = hval;
return(le);
@@ -108,11 +165,8 @@ tryagain:
(tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
return(le);
- le += n;
- if ((ndx += n) >= tbl->tsiz) { /* this happens rarely */
+ if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
ndx = ndx % tbl->tsiz;
/* table is full, reallocate */
le = tbl->tabl;
@@ -124,8 +178,6 @@ tryagain:
tbl->ndel = i;
return(NULL);
- if (!ndx)
- goto tryagain;
* The following code may fail if the user has reclaimed many
* deleted entries and the system runs out of memory in a
@@ -134,10 +186,10 @@ tryagain:
while (ndx--)
if (le[ndx].key != NULL)
if (le[ndx].data != NULL)
- *lu_find(tbl, le[ndx].key) = le[ndx];
+ copystruct(lu_find(tbl,le[ndx].key), &le[ndx]);
else if (tbl->freek != NULL)
(*tbl->freek)(le[ndx].key);
- free((MEM_PTR)le);
+ free((void *)le);
goto tryagain; /* should happen only once! */
@@ -160,6 +212,24 @@ char *key;
+int
+lu_doall(tbl, f) /* loop through all valid table entries */
+register LUTAB *tbl;
+int (*f)();
+ int rval = 0;
+ register LUENT *tp;
+ for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
+ if (tp->data != NULL)
+ if (f != NULL)
+ rval += (*f)(tp);
+ else
+ rval++;
+ return(rval);
void
lu_done(tbl) /* free table and contents */
@@ -175,7 +245,7 @@ register LUTAB *tbl;
if (tp->data != NULL && tbl->freed != NULL)
(*tbl->freed)(tp->data);
- free((MEM_PTR)tbl->tabl);
+ free((void *)tbl->tabl);
tbl->tabl = NULL;
tbl->tsiz = 0;
tbl->ndel = 0;
