root/Development/ray/src/common/lookup.c
Revision 2.19 - (view) (download) (annotate) - [selected]
Sun Feb 9 00:08:18 2014 UTC (11 years, 9 months ago) by greg
CVS Tags: HEAD, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 2.18: +17 -17 lines
Diff to previous 2.18
Fixed comment and removed pointless "register" modifiers
Fri Feb 18 00:40:25 2011 UTC (14 years, 8 months ago) by greg
Changes since 2.17: +8 -16 lines
Diff to previous 2.17 , to selected 2.19
Sat May 1 21:49:42 2010 UTC (15 years, 6 months ago) by greg
Diff to previous 2.16 , to selected 2.19
Removed C++ comments
Wed Jun 7 17:52:03 2006 UTC (19 years, 5 months ago) by schorsch
Changes since 2.15: +2 -1 lines
Diff to previous 2.15 , to selected 2.19
Tue May 25 22:04:13 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.14: +8 -8 lines
Diff to previous 2.14 , to selected 2.19
Tue May 25 06:30:46 2004 UTC (21 years, 5 months ago) by greg
Changes since 2.13: +9 -5 lines
Diff to previous 2.13 , to selected 2.19
Added argument for client data to lu_doall()
Sun Mar 28 20:33:12 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.12: +38 -23 lines
Diff to previous 2.12 , to selected 2.19
Fri Nov 21 07:15:29 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.11 , to selected 2.19
Wed Jul 30 10:11:06 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 2.10 , to selected 2.19
Mon Jul 21 22:30:17 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 2.9: +6 -11 lines
Diff to previous 2.9 , to selected 2.19
Mon Jun 30 14:59:11 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.8: +4 -2 lines
Diff to previous 2.8 , to selected 2.19
Tue May 13 17:58:32 2003 UTC (22 years, 6 months ago) by greg
Diff to previous 2.7 , to selected 2.19
Tue Feb 25 02:47:21 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.6 , to selected 2.19
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.5: +61 -10 lines
Diff to previous 2.5 , to selected 2.19
Thu Sep 3 14:22:23 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.4: +16 -15 lines
Diff to previous 2.4 , to selected 2.19
changed lookup routines to use unsigned long hash values
Tue Jun 2 15:01:43 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 2.3: +18 -0 lines
Diff to previous 2.3 , to selected 2.19
added lu_doall() function to loop through table entries
Wed Dec 3 10:59:30 1997 UTC (27 years, 11 months ago) by gregl
Changes since 2.2: +62 -23 lines
Diff to previous 2.2 , to selected 2.19
Added Philippe Bekaert's improvements to lu_hash() and lu_find()
Tue Apr 11 13:33:37 1995 UTC (30 years, 7 months ago) by greg
Diff to previous 2.1 , to selected 2.19
minor mods
Wed Jul 6 15:14:15 1994 UTC (31 years, 4 months ago) by greg
Diff to selected 2.19
