root/radiance/ray/src/common/lookup.c
Revision: 2.19
Committed: Sun Feb 9 00:08:18 2014 UTC (11 years, 6 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 2.18: +17 -17 lines
Fixed comment and removed pointless "register" modifiers
2 static const char RCSid[] = "$Id: lookup.c,v 2.18 2011/02/18 00:40:25 greg Exp $";
5 * Table lookup routines
6 */
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <string.h>
11
12 #include "lookup.h"
13
14
15 int
16 lu_init( /* initialize tbl for at least nel elements */
17 LUTAB *tbl,
18 int nel
19 )
20 {
21 static int hsiztab[] = {
22 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
23 32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
24 4194301, 8388593, 0
25 };
26 int *hsp;
27
28 nel += nel>>1; /* 66% occupancy */
29 for (hsp = hsiztab; *hsp; hsp++)
30 if (*hsp > nel)
31 break;
32 if (!(tbl->tsiz = *hsp))
33 tbl->tsiz = nel*2 + 1; /* not always prime */
34 tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
35 if (tbl->tabl == NULL)
36 tbl->tsiz = 0;
37 tbl->ndel = 0;
38 return(tbl->tsiz);
39 }
40
41
42 unsigned long
43 lu_shash( /* hash a nul-terminated string */
44 const char *s
45 )
46 {
47 static unsigned char shuffle[256] = {
48 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
49 191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
50 126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
51 61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
52 252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
53 187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
54 122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
55 57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
56 248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
57 183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
58 118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
59 53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
60 244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
61 179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
62 114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
63 49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
64 240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
65 175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
66 110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
67 45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
68 236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
69 171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
70 106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
71 41, 198, 99
72 };
73 int i = 0;
74 unsigned long h = 0;
75 unsigned const char *t = (unsigned const char *)s;
76
77 while (*t)
78 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
79
80 return(h);
81 }
82
83
84 LUENT *
85 lu_find( /* find a table entry */
86 LUTAB *tbl,
87 const char *key
88 )
89 {
90 unsigned long hval;
91 int i, n;
92 int ndx;
93 LUENT *le;
94 /* look up object */
95 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
96 return(NULL);
97 hval = (*tbl->hashf)(key);
98 tryagain:
99 ndx = hval % tbl->tsiz;
100 for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
101 le = &tbl->tabl[ndx];
102 if (le->key == NULL) {
103 le->hval = hval;
104 return(le);
105 }
106 if (le->hval == hval &&
107 (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
108 return(le);
109 }
110 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
111 ndx = ndx % tbl->tsiz;
112 }
113 /* table is full, reallocate */
114 le = tbl->tabl;
115 ndx = tbl->tsiz;
116 i = tbl->ndel;
117 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
118 tbl->tabl = le;
119 tbl->tsiz = ndx;
120 tbl->ndel = i;
121 return(NULL);
122 }
123 /*
124 * The following code may fail if the user has reclaimed many
125 * deleted entries and the system runs out of memory in a
126 * recursive call to lu_find().
127 */
128 while (ndx--)
129 if (le[ndx].key != NULL) {
130 if (le[ndx].data != NULL)
131 *lu_find(tbl,le[ndx].key) = le[ndx];
132 else if (tbl->freek != NULL)
133 (*tbl->freek)(le[ndx].key);
134 }
135 free((void *)le);
136 goto tryagain; /* should happen only once! */
137 }
138
139
140 void
141 lu_delete( /* delete a table entry */
142 LUTAB *tbl,
143 const char *key
144 )
145 {
146 LUENT *le;
147
148 if ((le = lu_find(tbl, key)) == NULL)
149 return;
150 if (le->key == NULL || le->data == NULL)
151 return;
152 if (tbl->freed != NULL)
153 (*tbl->freed)(le->data);
154 le->data = NULL;
155 tbl->ndel++;
156 }
157
158
159 int
160 lu_doall( /* loop through all valid table entries */
161 const LUTAB *tbl,
162 /* int (*f)(const LUENT *, void *) */
163 lut_doallf_t *f,
164 void *p
165 )
166 {
167 int rval = 0;
168 const LUENT *tp;
169
170 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
171 if (tp->data != NULL) {
172 if (f != NULL) {
173 int r = (*f)(tp, p);
174 if (r < 0)
175 return(-1);
176 rval += r;
177 } else
178 rval++;
179 }
180 return(rval);
181 }
182
183
184 void
185 lu_done( /* free table and contents */
186 LUTAB *tbl
187 )
188 {
189 LUENT *tp;
190
191 if (!tbl->tsiz)
192 return;
193 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
194 if (tp->key != NULL) {
195 if (tbl->freek != NULL)
196 (*tbl->freek)(tp->key);
197 if (tp->data != NULL && tbl->freed != NULL)
198 (*tbl->freed)(tp->data);
199 }
200 free((void *)tbl->tabl);
201 tbl->tabl = NULL;
202 tbl->tsiz = 0;
203 tbl->ndel = 0;
204 }
