--- ray/src/common/lookup.c 1997/12/03 10:59:30 2.3 +++ ray/src/common/lookup.c 2003/07/30 10:11:06 2.11 @@ -1,21 +1,18 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: lookup.c,v 2.11 2003/07/30 10:11:06 schorsch Exp $"; #endif - /* * Table lookup routines */ +#include "copyright.h" + #include +#include + #include "lookup.h" -#define MEM_PTR char * -extern MEM_PTR calloc(); - - int lu_init(tbl, nel) /* initialize tbl for at least nel elements */ register LUTAB *tbl; @@ -42,7 +39,7 @@ int nel; } -long +unsigned long lu_shash(s) /* hash a nul-terminated string */ char *s; { @@ -73,11 +70,11 @@ char *s; 41, 198, 99 }; register int i = 0; - register long h = 0; + register unsigned long h = 0; register unsigned char *t = (unsigned char *)s; while (*t) - h ^= (long)shuffle[*t++] << ((i+=11) & 0xf); + h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf); return(h); } @@ -88,18 +85,18 @@ lu_find(tbl, key) /* find a table entry */ register LUTAB *tbl; char *key; { - long hval; + unsigned long hval; int i, n; register int ndx; register LUENT *le; /* look up object */ - if (tbl->tsiz == 0) - lu_init(tbl, 1); + if (tbl->tsiz == 0 && !lu_init(tbl, 1)) + return(NULL); hval = (*tbl->hashf)(key); tryagain: ndx = hval % tbl->tsiz; - le = &tbl->tabl[ndx]; for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) { + le = &tbl->tabl[ndx]; if (le->key == NULL) { le->hval = hval; return(le); @@ -108,11 +105,8 @@ tryagain: (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) { return(le); } - le += n; - if ((ndx += n) >= tbl->tsiz) { /* this happens rarely */ + if ((ndx += n) >= tbl->tsiz) /* this happens rarely */ ndx = ndx % tbl->tsiz; - le = &tbl->tabl[ndx]; - } } /* table is full, reallocate */ le = tbl->tabl; @@ -124,20 +118,19 @@ tryagain: tbl->ndel = i; return(NULL); } - if (!ndx) - goto tryagain; /* * The following code may fail if the user has reclaimed many * deleted entries and the system runs out of memory in a * recursive call to lu_find(). */ while (ndx--) - if (le[ndx].key != NULL) + if (le[ndx].key != NULL) { if (le[ndx].data != NULL) - *lu_find(tbl, le[ndx].key) = le[ndx]; + *lu_find(tbl,le[ndx].key) = le[ndx]; else if (tbl->freek != NULL) (*tbl->freek)(le[ndx].key); - free((MEM_PTR)le); + } + free((void *)le); goto tryagain; /* should happen only once! */ } @@ -160,6 +153,25 @@ char *key; } +int +lu_doall(tbl, f) /* loop through all valid table entries */ +register LUTAB *tbl; +int (*f)(LUENT *); +{ + int rval = 0; + register LUENT *tp; + + for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; ) + if (tp->data != NULL) { + if (f != NULL) + rval += (*f)(tp); + else + rval++; + } + return(rval); +} + + void lu_done(tbl) /* free table and contents */ register LUTAB *tbl; @@ -175,7 +187,7 @@ register LUTAB *tbl; if (tp->data != NULL && tbl->freed != NULL) (*tbl->freed)(tp->data); } - free((MEM_PTR)tbl->tabl); + free((void *)tbl->tabl); tbl->tabl = NULL; tbl->tsiz = 0; tbl->ndel = 0;
