root/radiance/ray/src/common/lookup.c
Revision: 2.3
Committed: Wed Dec 3 10:59:30 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.2: +62 -23 lines
Added Philippe Bekaert's improvements to lu_hash() and lu_find()
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Table lookup routines
9 */
10
11 #include <stdio.h>
12 #include "lookup.h"
13
14 #define MEM_PTR char *
15
16 extern MEM_PTR calloc();
17
18
19 int
20 lu_init(tbl, nel) /* initialize tbl for at least nel elements */
21 register LUTAB *tbl;
22 int nel;
23 {
24 static int hsiztab[] = {
25 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
26 32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
27 4194301, 8388593, 0
28 };
29 register int *hsp;
30
31 nel += nel>>1; /* 66% occupancy */
32 for (hsp = hsiztab; *hsp; hsp++)
33 if (*hsp > nel)
34 break;
35 if (!(tbl->tsiz = *hsp))
36 tbl->tsiz = nel*2 + 1; /* not always prime */
37 tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
38 if (tbl->tabl == NULL)
39 tbl->tsiz = 0;
40 tbl->ndel = 0;
41 return(tbl->tsiz);
42 }
43
44
45 long
46 lu_shash(s) /* hash a nul-terminated string */
47 char *s;
48 {
49 static unsigned char shuffle[256] = {
50 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
51 191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
52 126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
53 61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
54 252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
55 187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
56 122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
57 57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
58 248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
59 183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
60 118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
61 53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
62 244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
63 179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
64 114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
65 49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
66 240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
67 175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
68 110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
69 45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
70 236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
71 171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
72 106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
73 41, 198, 99
74 };
75 register int i = 0;
76 register long h = 0;
77 register unsigned char *t = (unsigned char *)s;
78
79 while (*t)
80 h ^= (long)shuffle[*t++] << ((i+=11) & 0xf);
81
82 return(h);
83 }
84
85
86 LUENT *
87 lu_find(tbl, key) /* find a table entry */
88 register LUTAB *tbl;
89 char *key;
90 {
91 long hval;
92 int i, n;
93 register int ndx;
94 register LUENT *le;
95 /* look up object */
96 if (tbl->tsiz == 0)
97 lu_init(tbl, 1);
98 hval = (*tbl->hashf)(key);
99 tryagain:
100 ndx = hval % tbl->tsiz;
101 le = &tbl->tabl[ndx];
102 for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
103 if (le->key == NULL) {
104 le->hval = hval;
105 return(le);
106 }
107 if (le->hval == hval &&
108 (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
109 return(le);
110 }
111 le += n;
112 if ((ndx += n) >= tbl->tsiz) { /* this happens rarely */
113 ndx = ndx % tbl->tsiz;
114 le = &tbl->tabl[ndx];
115 }
116 }
117 /* table is full, reallocate */
118 le = tbl->tabl;
119 ndx = tbl->tsiz;
120 i = tbl->ndel;
121 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
122 tbl->tabl = le;
123 tbl->tsiz = ndx;
124 tbl->ndel = i;
125 return(NULL);
126 }
127 if (!ndx)
128 goto tryagain;
129 /*
130 * The following code may fail if the user has reclaimed many
131 * deleted entries and the system runs out of memory in a
132 * recursive call to lu_find().
133 */
134 while (ndx--)
135 if (le[ndx].key != NULL)
136 if (le[ndx].data != NULL)
137 *lu_find(tbl, le[ndx].key) = le[ndx];
138 else if (tbl->freek != NULL)
139 (*tbl->freek)(le[ndx].key);
140 free((MEM_PTR)le);
141 goto tryagain; /* should happen only once! */
142 }
143
144
145 void
146 lu_delete(tbl, key) /* delete a table entry */
147 register LUTAB *tbl;
148 char *key;
149 {
150 register LUENT *le;
151
152 if ((le = lu_find(tbl, key)) == NULL)
153 return;
154 if (le->key == NULL || le->data == NULL)
155 return;
156 if (tbl->freed != NULL)
157 (*tbl->freed)(le->data);
158 le->data = NULL;
159 tbl->ndel++;
160 }
161
162
163 void
164 lu_done(tbl) /* free table and contents */
165 register LUTAB *tbl;
166 {
167 register LUENT *tp;
168
169 if (!tbl->tsiz)
170 return;
171 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
172 if (tp->key != NULL) {
173 if (tbl->freek != NULL)
174 (*tbl->freek)(tp->key);
175 if (tp->data != NULL && tbl->freed != NULL)
176 (*tbl->freed)(tp->data);
177 }
178 free((MEM_PTR)tbl->tabl);
179 tbl->tabl = NULL;
180 tbl->tsiz = 0;
181 tbl->ndel = 0;
182 }
