root/radiance/ray/src/common/lookup.c
Revision: 2.19
Committed: Sun Feb 9 00:08:18 2014 UTC (10 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Changes since 2.18: +17 -17 lines
Fixed comment and removed pointless "register" modifiers
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.19 static const char RCSid[] = "$Id: lookup.c,v 2.18 2011/02/18 00:40:25 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Table lookup routines
6     */
7 greg 2.6
8 greg 2.1 #include <stdio.h>
9 greg 2.6 #include <stdlib.h>
10 schorsch 2.16 #include <string.h>
11 schorsch 2.9
12 greg 2.1 #include "lookup.h"
13
14
15 greg 2.18 int
16 schorsch 2.13 lu_init( /* initialize tbl for at least nel elements */
17 greg 2.19 LUTAB *tbl,
18 schorsch 2.13 int nel
19     )
20 greg 2.1 {
21     static int hsiztab[] = {
22 gregl 2.3 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
23     32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
24     4194301, 8388593, 0
25 greg 2.1 };
26 greg 2.19 int *hsp;
27 greg 2.1
28     nel += nel>>1; /* 66% occupancy */
29     for (hsp = hsiztab; *hsp; hsp++)
30     if (*hsp > nel)
31     break;
32     if (!(tbl->tsiz = *hsp))
33     tbl->tsiz = nel*2 + 1; /* not always prime */
34     tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
35     if (tbl->tabl == NULL)
36     tbl->tsiz = 0;
37     tbl->ndel = 0;
38     return(tbl->tsiz);
39     }
40
41
42 greg 2.18 unsigned long
43 schorsch 2.13 lu_shash( /* hash a nul-terminated string */
44 greg 2.18 const char *s
45 schorsch 2.13 )
46 greg 2.1 {
47 gregl 2.3 static unsigned char shuffle[256] = {
48     0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
49     191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
50     126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
51     61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
52     252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
53     187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
54     122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
55     57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
56     248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
57     183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
58     118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
59     53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
60     244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
61     179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
62     114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
63     49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
64     240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
65     175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
66     110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
67     45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
68     236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
69     171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
70     106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
71     41, 198, 99
72     };
73 greg 2.19 int i = 0;
74     unsigned long h = 0;
75     unsigned const char *t = (unsigned const char *)s;
76 greg 2.1
77 gregl 2.3 while (*t)
78 gwlarson 2.5 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
79 gregl 2.3
80 greg 2.1 return(h);
81     }
82
83
84 greg 2.18 LUENT *
85 schorsch 2.13 lu_find( /* find a table entry */
86 greg 2.19 LUTAB *tbl,
87 greg 2.15 const char *key
88 schorsch 2.13 )
89 greg 2.1 {
90 gwlarson 2.5 unsigned long hval;
91 gregl 2.3 int i, n;
92 greg 2.19 int ndx;
93     LUENT *le;
94 greg 2.1 /* look up object */
95 gwlarson 2.5 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
96     return(NULL);
97 greg 2.1 hval = (*tbl->hashf)(key);
98     tryagain:
99 gregl 2.3 ndx = hval % tbl->tsiz;
100     for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
101 gwlarson 2.5 le = &tbl->tabl[ndx];
102 gregl 2.3 if (le->key == NULL) {
103     le->hval = hval;
104     return(le);
105 greg 2.1 }
106 gregl 2.3 if (le->hval == hval &&
107     (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
108     return(le);
109     }
110 gwlarson 2.5 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
111 gregl 2.3 ndx = ndx % tbl->tsiz;
112 greg 2.1 }
113     /* table is full, reallocate */
114 gregl 2.3 le = tbl->tabl;
115 greg 2.1 ndx = tbl->tsiz;
116     i = tbl->ndel;
117 greg 2.2 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
118 gregl 2.3 tbl->tabl = le;
119 greg 2.1 tbl->tsiz = ndx;
120     tbl->ndel = i;
121     return(NULL);
122     }
123     /*
124     * The following code may fail if the user has reclaimed many
125     * deleted entries and the system runs out of memory in a
126     * recursive call to lu_find().
127     */
128     while (ndx--)
129 schorsch 2.10 if (le[ndx].key != NULL) {
130 gregl 2.3 if (le[ndx].data != NULL)
131 schorsch 2.10 *lu_find(tbl,le[ndx].key) = le[ndx];
132 greg 2.1 else if (tbl->freek != NULL)
133 gregl 2.3 (*tbl->freek)(le[ndx].key);
134 schorsch 2.10 }
135 greg 2.6 free((void *)le);
136 greg 2.1 goto tryagain; /* should happen only once! */
137     }
138
139
140 greg 2.18 void
141 schorsch 2.13 lu_delete( /* delete a table entry */
142 greg 2.19 LUTAB *tbl,
143     const char *key
144 schorsch 2.13 )
145 greg 2.1 {
146 greg 2.19 LUENT *le;
147 greg 2.1
148     if ((le = lu_find(tbl, key)) == NULL)
149     return;
150     if (le->key == NULL || le->data == NULL)
151     return;
152     if (tbl->freed != NULL)
153     (*tbl->freed)(le->data);
154     le->data = NULL;
155     tbl->ndel++;
156     }
157
158
159 greg 2.18 int
160 schorsch 2.13 lu_doall( /* loop through all valid table entries */
161 greg 2.19 const LUTAB *tbl,
162     /* int (*f)(const LUENT *, void *) */
163 greg 2.14 lut_doallf_t *f,
164     void *p
165 schorsch 2.13 )
166 gwlarson 2.4 {
167     int rval = 0;
168 greg 2.19 const LUENT *tp;
169 gwlarson 2.4
170     for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
171 schorsch 2.10 if (tp->data != NULL) {
172 greg 2.14 if (f != NULL) {
173     int r = (*f)(tp, p);
174     if (r < 0)
175     return(-1);
176     rval += r;
177     } else
178 gwlarson 2.4 rval++;
179 schorsch 2.10 }
180 gwlarson 2.4 return(rval);
181     }
182
183
184 greg 2.18 void
185 schorsch 2.13 lu_done( /* free table and contents */
186 greg 2.19 LUTAB *tbl
187 schorsch 2.13 )
188 greg 2.1 {
189 greg 2.19 LUENT *tp;
190 greg 2.1
191     if (!tbl->tsiz)
192     return;
193     for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
194     if (tp->key != NULL) {
195     if (tbl->freek != NULL)
196     (*tbl->freek)(tp->key);
197     if (tp->data != NULL && tbl->freed != NULL)
198     (*tbl->freed)(tp->data);
199     }
200 greg 2.6 free((void *)tbl->tabl);
201 greg 2.1 tbl->tabl = NULL;
202     tbl->tsiz = 0;
203     tbl->ndel = 0;
204     }
