root/radiance/ray/src/common/lookup.c
Revision: 2.8
Committed: Tue May 13 17:58:32 2003 UTC (21 years, 11 months ago) by greg
5 * Table lookup routines
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include "lookup.h"
13
14 #ifdef NOSTRUCTASS
15 #define copystruct(d,s) bcopy((void *)(s),(void *)(d),sizeof(*(d)))
16 #else
17 #define copystruct(d,s) (*(d) = *(s))
18 #endif
19
20
21 int
22 lu_init(tbl, nel) /* initialize tbl for at least nel elements */
23 register LUTAB *tbl;
24 int nel;
25 {
26 static int hsiztab[] = {
27 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
28 32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
29 4194301, 8388593, 0
30 };
31 register int *hsp;
32
33 nel += nel>>1; /* 66% occupancy */
34 for (hsp = hsiztab; *hsp; hsp++)
35 if (*hsp > nel)
36 break;
37 if (!(tbl->tsiz = *hsp))
38 tbl->tsiz = nel*2 + 1; /* not always prime */
39 tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
40 if (tbl->tabl == NULL)
41 tbl->tsiz = 0;
42 tbl->ndel = 0;
43 return(tbl->tsiz);
44 }
45
46
47 unsigned long
48 lu_shash(s) /* hash a nul-terminated string */
49 char *s;
50 {
51 static unsigned char shuffle[256] = {
52 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
53 191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
54 126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
55 61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
56 252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
57 187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
58 122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
59 57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
60 248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
61 183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
62 118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
63 53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
64 244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
65 179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
66 114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
67 49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
68 240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
69 175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
70 110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
71 45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
72 236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
73 171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
74 106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
75 41, 198, 99
76 };
77 register int i = 0;
78 register unsigned long h = 0;
79 register unsigned char *t = (unsigned char *)s;
80
81 while (*t)
82 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
83
84 return(h);
85 }
86
87
88 LUENT *
89 lu_find(tbl, key) /* find a table entry */
90 register LUTAB *tbl;
91 char *key;
92 {
93 unsigned long hval;
94 int i, n;
95 register int ndx;
96 register LUENT *le;
97 /* look up object */
98 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
99 return(NULL);
100 hval = (*tbl->hashf)(key);
101 tryagain:
102 ndx = hval % tbl->tsiz;
103 for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
104 le = &tbl->tabl[ndx];
105 if (le->key == NULL) {
106 le->hval = hval;
107 return(le);
108 }
109 if (le->hval == hval &&
110 (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
111 return(le);
112 }
113 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
114 ndx = ndx % tbl->tsiz;
115 }
116 /* table is full, reallocate */
117 le = tbl->tabl;
118 ndx = tbl->tsiz;
119 i = tbl->ndel;
120 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
121 tbl->tabl = le;
122 tbl->tsiz = ndx;
123 tbl->ndel = i;
124 return(NULL);
125 }
126 /*
127 * The following code may fail if the user has reclaimed many
128 * deleted entries and the system runs out of memory in a
129 * recursive call to lu_find().
130 */
131 while (ndx--)
132 if (le[ndx].key != NULL)
133 if (le[ndx].data != NULL)
134 copystruct(lu_find(tbl,le[ndx].key), &le[ndx]);
135 else if (tbl->freek != NULL)
136 (*tbl->freek)(le[ndx].key);
137 free((void *)le);
138 goto tryagain; /* should happen only once! */
139 }
140
141
142 void
143 lu_delete(tbl, key) /* delete a table entry */
144 register LUTAB *tbl;
145 char *key;
146 {
147 register LUENT *le;
148
149 if ((le = lu_find(tbl, key)) == NULL)
150 return;
151 if (le->key == NULL || le->data == NULL)
152 return;
153 if (tbl->freed != NULL)
154 (*tbl->freed)(le->data);
155 le->data = NULL;
156 tbl->ndel++;
157 }
158
159
160 int
161 lu_doall(tbl, f) /* loop through all valid table entries */
162 register LUTAB *tbl;
163 int (*f)();
164 {
165 int rval = 0;
166 register LUENT *tp;
167
168 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
169 if (tp->data != NULL)
170 if (f != NULL)
171 rval += (*f)(tp);
172 else
173 rval++;
174 return(rval);
175 }
176
177
178 void
179 lu_done(tbl) /* free table and contents */
180 register LUTAB *tbl;
181 {
182 register LUENT *tp;
183
184 if (!tbl->tsiz)
185 return;
186 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
187 if (tp->key != NULL) {
188 if (tbl->freek != NULL)
189 (*tbl->freek)(tp->key);
190 if (tp->data != NULL && tbl->freed != NULL)
191 (*tbl->freed)(tp->data);
192 }
193 free((void *)tbl->tabl);
194 tbl->tabl = NULL;
195 tbl->tsiz = 0;
196 tbl->ndel = 0;
197 }
