--- ray/src/common/lookup.c 1998/09/03 14:22:23 2.5 +++ ray/src/common/lookup.c 2010/05/01 21:49:42 2.17 @@ -1,31 +1,30 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: lookup.c,v 2.17 2010/05/01 21:49:42 greg Exp $"; #endif - /* * Table lookup routines */ #include +#include +#include + #include "lookup.h" -#ifdef NOSTRUCTASS -#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) -#else -#define copystruct(d,s) (*(d) = *(s)) -#endif +extern int +lu_strcmp( + const void *s1, + const void *s2 +) +{ + return strcmp((const char*)s1,(const char*)s2); +} -#define MEM_PTR char * - -extern MEM_PTR calloc(); - - -int -lu_init(tbl, nel) /* initialize tbl for at least nel elements */ -register LUTAB *tbl; -int nel; +extern int +lu_init( /* initialize tbl for at least nel elements */ + register LUTAB *tbl, + int nel +) { static int hsiztab[] = { 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381, @@ -48,9 +47,10 @@ int nel; } -unsigned long -lu_shash(s) /* hash a nul-terminated string */ -char *s; +extern unsigned long +lu_shash( /* hash a nul-terminated string */ + const void *s +) { static unsigned char shuffle[256] = { 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34, @@ -80,7 +80,7 @@ char *s; }; register int i = 0; register unsigned long h = 0; - register unsigned char *t = (unsigned char *)s; + register unsigned const char *t = (unsigned const char *)s; while (*t) h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf); @@ -89,10 +89,11 @@ char *s; } -LUENT * -lu_find(tbl, key) /* find a table entry */ -register LUTAB *tbl; -char *key; +extern LUENT * +lu_find( /* find a table entry */ + register LUTAB *tbl, + const char *key +) { unsigned long hval; int i, n; @@ -133,20 +134,22 @@ tryagain: * recursive call to lu_find(). */ while (ndx--) - if (le[ndx].key != NULL) + if (le[ndx].key != NULL) { if (le[ndx].data != NULL) - copystruct(lu_find(tbl,le[ndx].key), &le[ndx]); + *lu_find(tbl,le[ndx].key) = le[ndx]; else if (tbl->freek != NULL) (*tbl->freek)(le[ndx].key); - free((MEM_PTR)le); + } + free((void *)le); goto tryagain; /* should happen only once! */ } -void -lu_delete(tbl, key) /* delete a table entry */ -register LUTAB *tbl; -char *key; +extern void +lu_delete( /* delete a table entry */ + register LUTAB *tbl, + const char *key +) { register LUENT *le; @@ -161,27 +164,35 @@ char *key; } -int -lu_doall(tbl, f) /* loop through all valid table entries */ -register LUTAB *tbl; -int (*f)(); +extern int +lu_doall( /* loop through all valid table entries */ + register const LUTAB *tbl, + /* int (*f)(const LUENT *) */ + lut_doallf_t *f, + void *p +) { int rval = 0; - register LUENT *tp; + register const LUENT *tp; for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; ) - if (tp->data != NULL) - if (f != NULL) - rval += (*f)(tp); - else + if (tp->data != NULL) { + if (f != NULL) { + int r = (*f)(tp, p); + if (r < 0) + return(-1); + rval += r; + } else rval++; + } return(rval); } -void -lu_done(tbl) /* free table and contents */ -register LUTAB *tbl; +extern void +lu_done( /* free table and contents */ + register LUTAB *tbl +) { register LUENT *tp; @@ -194,7 +205,7 @@ register LUTAB *tbl; if (tp->data != NULL && tbl->freed != NULL) (*tbl->freed)(tp->data); } - free((MEM_PTR)tbl->tabl); + free((void *)tbl->tabl); tbl->tabl = NULL; tbl->tsiz = 0; tbl->ndel = 0;
