| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: lookup.c,v 2.15 2004/05/25 22:04:13 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Table lookup routines
| 6 |
| 7 |
| 8 |
#include <stdio.h>
| 9 |
#include <stdlib.h>
| 10 |
#include <string.h>
| 11 |
| 12 |
#include "lookup.h"
| 13 |
| 14 |
extern int
| 15 |
lu_strcmp(
| 16 |
const void *s1,
| 17 |
const void *s2
| 18 |
| 19 |
| 20 |
return strcmp((const char*)s1,(const char*)s2);
| 21 |
| 22 |
| 23 |
extern int
| 24 |
lu_init( /* initialize tbl for at least nel elements */
| 25 |
register LUTAB *tbl,
| 26 |
int nel
| 27 |
| 28 |
| 29 |
static int hsiztab[] = {
| 30 |
31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
| 31 |
32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
| 32 |
4194301, 8388593, 0
| 33 |
| 34 |
register int *hsp;
| 35 |
| 36 |
nel += nel>>1; /* 66% occupancy */
| 37 |
for (hsp = hsiztab; *hsp; hsp++)
| 38 |
if (*hsp > nel)
| 39 |
break;
| 40 |
if (!(tbl->tsiz = *hsp))
| 41 |
tbl->tsiz = nel*2 + 1; /* not always prime */
| 42 |
tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
| 43 |
if (tbl->tabl == NULL)
| 44 |
tbl->tsiz = 0;
| 45 |
tbl->ndel = 0;
| 46 |
return(tbl->tsiz);
| 47 |
| 48 |
| 49 |
| 50 |
extern unsigned long
| 51 |
lu_shash( /* hash a nul-terminated string */
| 52 |
const void *s
| 53 |
| 54 |
| 55 |
static unsigned char shuffle[256] = {
| 56 |
0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
| 57 |
191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
| 58 |
126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
| 59 |
61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
| 60 |
252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
| 61 |
187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
| 62 |
122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
| 63 |
57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
| 64 |
248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
| 65 |
183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
| 66 |
118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
| 67 |
53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
| 68 |
244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
| 69 |
179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
| 70 |
114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
| 71 |
49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
| 72 |
240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
| 73 |
175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
| 74 |
110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
| 75 |
45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
| 76 |
236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
| 77 |
171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
| 78 |
106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
| 79 |
41, 198, 99
| 80 |
| 81 |
register int i = 0;
| 82 |
register unsigned long h = 0;
| 83 |
register unsigned const char *t = (unsigned const char *)s;
| 84 |
| 85 |
while (*t)
| 86 |
h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
| 87 |
| 88 |
return(h);
| 89 |
| 90 |
| 91 |
| 92 |
extern LUENT *
| 93 |
lu_find( /* find a table entry */
| 94 |
| 95 |
const char *key
| 96 |
| 97 |
| 98 |
unsigned long hval;
| 99 |
int i, n;
| 100 |
register int ndx;
| 101 |
register LUENT *le;
| 102 |
/* look up object */
| 103 |
if (tbl->tsiz == 0 && !lu_init(tbl, 1))
| 104 |
return(NULL);
| 105 |
hval = (*tbl->hashf)(key);
| 106 |
tryagain:
| 107 |
ndx = hval % tbl->tsiz;
| 108 |
for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
| 109 |
le = &tbl->tabl[ndx];
| 110 |
if (le->key == NULL) {
| 111 |
le->hval = hval;
| 112 |
return(le);
| 113 |
| 114 |
if (le->hval == hval &&
| 115 |
(tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
| 116 |
return(le);
| 117 |
| 118 |
if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
| 119 |
ndx = ndx % tbl->tsiz;
| 120 |
| 121 |
/* table is full, reallocate */
| 122 |
le = tbl->tabl;
| 123 |
ndx = tbl->tsiz;
| 124 |
i = tbl->ndel;
| 125 |
if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
| 126 |
tbl->tabl = le;
| 127 |
tbl->tsiz = ndx;
| 128 |
tbl->ndel = i;
| 129 |
return(NULL);
| 130 |
| 131 |
| 132 |
* The following code may fail if the user has reclaimed many
| 133 |
* deleted entries and the system runs out of memory in a
| 134 |
* recursive call to lu_find().
| 135 |
| 136 |
while (ndx--)
| 137 |
if (le[ndx].key != NULL) {
| 138 |
if (le[ndx].data != NULL)
| 139 |
*lu_find(tbl,le[ndx].key) = le[ndx];
| 140 |
else if (tbl->freek != NULL)
| 141 |
(*tbl->freek)(le[ndx].key);
| 142 |
| 143 |
free((void *)le);
| 144 |
goto tryagain; /* should happen only once! */
| 145 |
| 146 |
| 147 |
| 148 |
extern void
| 149 |
lu_delete( /* delete a table entry */
| 150 |
| 151 |
const char *key
| 152 |
| 153 |
| 154 |
register LUENT *le;
| 155 |
| 156 |
if ((le = lu_find(tbl, key)) == NULL)
| 157 |
return;
| 158 |
if (le->key == NULL || le->data == NULL)
| 159 |
return;
| 160 |
if (tbl->freed != NULL)
| 161 |
(*tbl->freed)(le->data);
| 162 |
le->data = NULL;
| 163 |
tbl->ndel++;
| 164 |
| 165 |
| 166 |
| 167 |
extern int
| 168 |
lu_doall( /* loop through all valid table entries */
| 169 |
register const LUTAB *tbl,
| 170 |
//int (*f)(const LUENT *)
| 171 |
lut_doallf_t *f,
| 172 |
void *p
| 173 |
| 174 |
| 175 |
int rval = 0;
| 176 |
register const LUENT *tp;
| 177 |
| 178 |
for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
| 179 |
if (tp->data != NULL) {
| 180 |
if (f != NULL) {
| 181 |
int r = (*f)(tp, p);
| 182 |
if (r < 0)
| 183 |
return(-1);
| 184 |
rval += r;
| 185 |
} else
| 186 |
rval++;
| 187 |
| 188 |
return(rval);
| 189 |
| 190 |
| 191 |
| 192 |
extern void
| 193 |
lu_done( /* free table and contents */
| 194 |
register LUTAB *tbl
| 195 |
| 196 |
| 197 |
register LUENT *tp;
| 198 |
| 199 |
if (!tbl->tsiz)
| 200 |
return;
| 201 |
| 202 |
if (tp->key != NULL) {
| 203 |
| 204 |
(*tbl->freek)(tp->key);
| 205 |
if (tp->data != NULL && tbl->freed != NULL)
| 206 |
(*tbl->freed)(tp->data);
| 207 |
| 208 |
free((void *)tbl->tabl);
| 209 |
tbl->tabl = NULL;
| 210 |
tbl->tsiz = 0;
| 211 |
tbl->ndel = 0;
| 212 |
