--- ray/src/common/lookup.c 1994/07/06 15:14:15 2.1 +++ ray/src/common/lookup.c 1998/09/03 14:22:23 2.5 @@ -1,7 +1,7 @@ -/* Copyright (c) 1994 Regents of the University of California */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static char SCCSid[] = "$SunId$ SGI"; #endif /* @@ -11,6 +11,12 @@ static char SCCSid[] = "$SunId$ LBL"; #include #include "lookup.h" +#ifdef NOSTRUCTASS +#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d))) +#else +#define copystruct(d,s) (*(d) = *(s)) +#endif + #define MEM_PTR char * extern MEM_PTR calloc(); @@ -22,7 +28,9 @@ register LUTAB *tbl; int nel; { static int hsiztab[] = { - 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381, 0 + 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381, + 32749, 65521, 131071, 262139, 524287, 1048573, 2097143, + 4194301, 8388593, 0 }; register int *hsp; @@ -40,15 +48,43 @@ int nel; } -long +unsigned long lu_shash(s) /* hash a nul-terminated string */ -register char *s; +char *s; { + static unsigned char shuffle[256] = { + 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34, + 191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225, + 126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160, + 61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95, + 252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30, + 187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221, + 122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156, + 57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91, + 248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26, + 183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217, + 118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152, + 53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87, + 244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22, + 179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213, + 114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148, + 49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83, + 240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18, + 175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209, + 110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144, + 45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79, + 236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14, + 171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205, + 106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140, + 41, 198, 99 + }; register int i = 0; - register long h = 0; + register unsigned long h = 0; + register unsigned char *t = (unsigned char *)s; - while (*s) - h ^= (long)(*s++ & 0xff) << (i++ & 15); + while (*t) + h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf); + return(h); } @@ -58,47 +94,51 @@ lu_find(tbl, key) /* find a table entry */ register LUTAB *tbl; char *key; { - long hval; - int i; + unsigned long hval; + int i, n; register int ndx; - register LUENT *oldtabl; + register LUENT *le; /* look up object */ + if (tbl->tsiz == 0 && !lu_init(tbl, 1)) + return(NULL); hval = (*tbl->hashf)(key); tryagain: - for (i = 0; i < tbl->tsiz; i++) { - ndx = (hval + i*i) % tbl->tsiz; - if (tbl->tabl[ndx].key == NULL) { - tbl->tabl[ndx].hval = hval; - return(&tbl->tabl[ndx]); + ndx = hval % tbl->tsiz; + for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) { + le = &tbl->tabl[ndx]; + if (le->key == NULL) { + le->hval = hval; + return(le); } - if ( tbl->tabl[ndx].hval == hval && (tbl->keycmp == NULL || - !(*tbl->keycmp)(tbl->tabl[ndx].key, key)) ) - return(&tbl->tabl[ndx]); + if (le->hval == hval && + (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) { + return(le); + } + if ((ndx += n) >= tbl->tsiz) /* this happens rarely */ + ndx = ndx % tbl->tsiz; } /* table is full, reallocate */ - oldtabl = tbl->tabl; + le = tbl->tabl; ndx = tbl->tsiz; i = tbl->ndel; - if (!lu_init(tbl, ndx-i)) { /* no more memory! */ - tbl->tabl = oldtabl; + if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */ + tbl->tabl = le; tbl->tsiz = ndx; tbl->ndel = i; return(NULL); } - if (!ndx) - goto tryagain; /* * The following code may fail if the user has reclaimed many * deleted entries and the system runs out of memory in a * recursive call to lu_find(). */ while (ndx--) - if (oldtabl[ndx].key != NULL) - if (oldtabl[ndx].data != NULL) - *lu_find(tbl, oldtabl[ndx].key) = oldtabl[ndx]; + if (le[ndx].key != NULL) + if (le[ndx].data != NULL) + copystruct(lu_find(tbl,le[ndx].key), &le[ndx]); else if (tbl->freek != NULL) - (*tbl->freek)(oldtabl[ndx].key); - free((MEM_PTR)oldtabl); + (*tbl->freek)(le[ndx].key); + free((MEM_PTR)le); goto tryagain; /* should happen only once! */ } @@ -118,6 +158,24 @@ char *key; (*tbl->freed)(le->data); le->data = NULL; tbl->ndel++; +} + + +int +lu_doall(tbl, f) /* loop through all valid table entries */ +register LUTAB *tbl; +int (*f)(); +{ + int rval = 0; + register LUENT *tp; + + for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; ) + if (tp->data != NULL) + if (f != NULL) + rval += (*f)(tp); + else + rval++; + return(rval); }
