--- ray/src/common/lookup.c 1998/06/02 15:01:43 2.4 +++ ray/src/common/lookup.c 2004/05/25 06:30:46 2.14 @@ -1,25 +1,29 @@ -/* Copyright (c) 1997 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: lookup.c,v 2.14 2004/05/25 06:30:46 greg Exp $"; #endif - /* * Table lookup routines */ #include +#include + #include "lookup.h" -#define MEM_PTR char * +extern int +lu_strcmp( + const void *s1, + const void *s2 +) +{ + return strcmp((const char*)s1,(const char*)s2); +} -extern MEM_PTR calloc(); - - -int -lu_init(tbl, nel) /* initialize tbl for at least nel elements */ -register LUTAB *tbl; -int nel; +extern int +lu_init( /* initialize tbl for at least nel elements */ + register LUTAB *tbl, + int nel +) { static int hsiztab[] = { 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381, @@ -42,9 +46,10 @@ int nel; } -long -lu_shash(s) /* hash a nul-terminated string */ -char *s; +extern unsigned long +lu_shash( /* hash a nul-terminated string */ + void *s +) { static unsigned char shuffle[256] = { 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34, @@ -73,33 +78,34 @@ char *s; 41, 198, 99 }; register int i = 0; - register long h = 0; + register unsigned long h = 0; register unsigned char *t = (unsigned char *)s; while (*t) - h ^= (long)shuffle[*t++] << ((i+=11) & 0xf); + h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf); return(h); } -LUENT * -lu_find(tbl, key) /* find a table entry */ -register LUTAB *tbl; -char *key; +extern LUENT * +lu_find( /* find a table entry */ + register LUTAB *tbl, + char *key +) { - long hval; + unsigned long hval; int i, n; register int ndx; register LUENT *le; /* look up object */ - if (tbl->tsiz == 0) - lu_init(tbl, 1); + if (tbl->tsiz == 0 && !lu_init(tbl, 1)) + return(NULL); hval = (*tbl->hashf)(key); tryagain: ndx = hval % tbl->tsiz; - le = &tbl->tabl[ndx]; for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) { + le = &tbl->tabl[ndx]; if (le->key == NULL) { le->hval = hval; return(le); @@ -108,11 +114,8 @@ tryagain: (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) { return(le); } - le += n; - if ((ndx += n) >= tbl->tsiz) { /* this happens rarely */ + if ((ndx += n) >= tbl->tsiz) /* this happens rarely */ ndx = ndx % tbl->tsiz; - le = &tbl->tabl[ndx]; - } } /* table is full, reallocate */ le = tbl->tabl; @@ -124,28 +127,28 @@ tryagain: tbl->ndel = i; return(NULL); } - if (!ndx) - goto tryagain; /* * The following code may fail if the user has reclaimed many * deleted entries and the system runs out of memory in a * recursive call to lu_find(). */ while (ndx--) - if (le[ndx].key != NULL) + if (le[ndx].key != NULL) { if (le[ndx].data != NULL) - *lu_find(tbl, le[ndx].key) = le[ndx]; + *lu_find(tbl,le[ndx].key) = le[ndx]; else if (tbl->freek != NULL) (*tbl->freek)(le[ndx].key); - free((MEM_PTR)le); + } + free((void *)le); goto tryagain; /* should happen only once! */ } -void -lu_delete(tbl, key) /* delete a table entry */ -register LUTAB *tbl; -char *key; +extern void +lu_delete( /* delete a table entry */ + register LUTAB *tbl, + char *key +) { register LUENT *le; @@ -160,27 +163,35 @@ char *key; } -int -lu_doall(tbl, f) /* loop through all valid table entries */ -register LUTAB *tbl; -int (*f)(); +extern int +lu_doall( /* loop through all valid table entries */ + register LUTAB *tbl, + //int (*f)(LUENT *) + lut_doallf_t *f, + void *p +) { int rval = 0; register LUENT *tp; for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; ) - if (tp->data != NULL) - if (f != NULL) - rval += (*f)(tp); - else + if (tp->data != NULL) { + if (f != NULL) { + int r = (*f)(tp, p); + if (r < 0) + return(-1); + rval += r; + } else rval++; + } return(rval); } -void -lu_done(tbl) /* free table and contents */ -register LUTAB *tbl; +extern void +lu_done( /* free table and contents */ + register LUTAB *tbl +) { register LUENT *tp; @@ -193,7 +204,7 @@ register LUTAB *tbl; if (tp->data != NULL && tbl->freed != NULL) (*tbl->freed)(tp->data); } - free((MEM_PTR)tbl->tabl); + free((void *)tbl->tabl); tbl->tabl = NULL; tbl->tsiz = 0; tbl->ndel = 0;
