root/Development/ray/src/common/lookup.c
Revision: 2.15
Committed: Tue May 25 22:04:13 2004 UTC (21 years, 7 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Changes since 2.14: +8 -8 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.15 static const char RCSid[] = "$Id: lookup.c,v 2.14 2004/05/25 06:30:46 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Table lookup routines
6     */
7 greg 2.6
8 greg 2.1 #include <stdio.h>
9 greg 2.6 #include <stdlib.h>
10 schorsch 2.9
11 greg 2.1 #include "lookup.h"
12
13 schorsch 2.13 extern int
14     lu_strcmp(
15     const void *s1,
16     const void *s2
17     )
18     {
19     return strcmp((const char*)s1,(const char*)s2);
20     }
21 greg 2.1
22 schorsch 2.13 extern int
23     lu_init( /* initialize tbl for at least nel elements */
24     register LUTAB *tbl,
25     int nel
26     )
27 greg 2.1 {
28     static int hsiztab[] = {
29 gregl 2.3 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
30     32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
31     4194301, 8388593, 0
32 greg 2.1 };
33     register int *hsp;
34
35     nel += nel>>1; /* 66% occupancy */
36     for (hsp = hsiztab; *hsp; hsp++)
37     if (*hsp > nel)
38     break;
39     if (!(tbl->tsiz = *hsp))
40     tbl->tsiz = nel*2 + 1; /* not always prime */
41     tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
42     if (tbl->tabl == NULL)
43     tbl->tsiz = 0;
44     tbl->ndel = 0;
45     return(tbl->tsiz);
46     }
47
48
49 schorsch 2.13 extern unsigned long
50     lu_shash( /* hash a nul-terminated string */
51 greg 2.15 const void *s
52 schorsch 2.13 )
53 greg 2.1 {
54 gregl 2.3 static unsigned char shuffle[256] = {
55     0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
56     191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
57     126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
58     61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
59     252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
60     187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
61     122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
62     57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
63     248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
64     183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
65     118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
66     53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
67     244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
68     179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
69     114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
70     49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
71     240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
72     175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
73     110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
74     45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
75     236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
76     171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
77     106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
78     41, 198, 99
79     };
80 greg 2.1 register int i = 0;
81 gwlarson 2.5 register unsigned long h = 0;
82 greg 2.15 register unsigned const char *t = (unsigned const char *)s;
83 greg 2.1
84 gregl 2.3 while (*t)
85 gwlarson 2.5 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
86 gregl 2.3
87 greg 2.1 return(h);
88     }
89
90
91 schorsch 2.13 extern LUENT *
92     lu_find( /* find a table entry */
93     register LUTAB *tbl,
94 greg 2.15 const char *key
95 schorsch 2.13 )
96 greg 2.1 {
97 gwlarson 2.5 unsigned long hval;
98 gregl 2.3 int i, n;
99 greg 2.1 register int ndx;
100 gregl 2.3 register LUENT *le;
101 greg 2.1 /* look up object */
102 gwlarson 2.5 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
103     return(NULL);
104 greg 2.1 hval = (*tbl->hashf)(key);
105     tryagain:
106 gregl 2.3 ndx = hval % tbl->tsiz;
107     for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
108 gwlarson 2.5 le = &tbl->tabl[ndx];
109 gregl 2.3 if (le->key == NULL) {
110     le->hval = hval;
111     return(le);
112 greg 2.1 }
113 gregl 2.3 if (le->hval == hval &&
114     (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
115     return(le);
116     }
117 gwlarson 2.5 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
118 gregl 2.3 ndx = ndx % tbl->tsiz;
119 greg 2.1 }
120     /* table is full, reallocate */
121 gregl 2.3 le = tbl->tabl;
122 greg 2.1 ndx = tbl->tsiz;
123     i = tbl->ndel;
124 greg 2.2 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
125 gregl 2.3 tbl->tabl = le;
126 greg 2.1 tbl->tsiz = ndx;
127     tbl->ndel = i;
128     return(NULL);
129     }
130     /*
131     * The following code may fail if the user has reclaimed many
132     * deleted entries and the system runs out of memory in a
133     * recursive call to lu_find().
134     */
135     while (ndx--)
136 schorsch 2.10 if (le[ndx].key != NULL) {
137 gregl 2.3 if (le[ndx].data != NULL)
138 schorsch 2.10 *lu_find(tbl,le[ndx].key) = le[ndx];
139 greg 2.1 else if (tbl->freek != NULL)
140 gregl 2.3 (*tbl->freek)(le[ndx].key);
141 schorsch 2.10 }
142 greg 2.6 free((void *)le);
143 greg 2.1 goto tryagain; /* should happen only once! */
144     }
145
146
147 schorsch 2.13 extern void
148     lu_delete( /* delete a table entry */
149     register LUTAB *tbl,
150 greg 2.15 const char *key
151 schorsch 2.13 )
152 greg 2.1 {
153     register LUENT *le;
154
155     if ((le = lu_find(tbl, key)) == NULL)
156     return;
157     if (le->key == NULL || le->data == NULL)
158     return;
159     if (tbl->freed != NULL)
160     (*tbl->freed)(le->data);
161     le->data = NULL;
162     tbl->ndel++;
163     }
164
165
166 schorsch 2.13 extern int
167     lu_doall( /* loop through all valid table entries */
168 greg 2.15 register const LUTAB *tbl,
169     //int (*f)(const LUENT *)
170 greg 2.14 lut_doallf_t *f,
171     void *p
172 schorsch 2.13 )
173 gwlarson 2.4 {
174     int rval = 0;
175 greg 2.15 register const LUENT *tp;
176 gwlarson 2.4
177     for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
178 schorsch 2.10 if (tp->data != NULL) {
179 greg 2.14 if (f != NULL) {
180     int r = (*f)(tp, p);
181     if (r < 0)
182     return(-1);
183     rval += r;
184     } else
185 gwlarson 2.4 rval++;
186 schorsch 2.10 }
187 gwlarson 2.4 return(rval);
188     }
189
190
191 schorsch 2.13 extern void
192     lu_done( /* free table and contents */
193     register LUTAB *tbl
194     )
195 greg 2.1 {
196     register LUENT *tp;
197
198     if (!tbl->tsiz)
199     return;
200     for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
201     if (tp->key != NULL) {
202     if (tbl->freek != NULL)
203     (*tbl->freek)(tp->key);
204     if (tp->data != NULL && tbl->freed != NULL)
205     (*tbl->freed)(tp->data);
206     }
207 greg 2.6 free((void *)tbl->tabl);
208 greg 2.1 tbl->tabl = NULL;
209     tbl->tsiz = 0;
210     tbl->ndel = 0;
211     }
