root/radiance/ray/src/common/lookup.c
Revision: 2.10
Committed: Mon Jul 21 22:30:17 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.9: +6 -11 lines
2 static const char RCSid[] = "$Id: lookup.c,v 2.9 2003/06/30 14:59:11 schorsch Exp $";
5 * Table lookup routines
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <stdlib.h>
12
13 #include "lookup.h"
14
15
16 int
17 lu_init(tbl, nel) /* initialize tbl for at least nel elements */
18 register LUTAB *tbl;
19 int nel;
20 {
21 static int hsiztab[] = {
22 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
23 32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
24 4194301, 8388593, 0
25 };
26 register int *hsp;
27
28 nel += nel>>1; /* 66% occupancy */
29 for (hsp = hsiztab; *hsp; hsp++)
30 if (*hsp > nel)
31 break;
32 if (!(tbl->tsiz = *hsp))
33 tbl->tsiz = nel*2 + 1; /* not always prime */
34 tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
35 if (tbl->tabl == NULL)
36 tbl->tsiz = 0;
37 tbl->ndel = 0;
38 return(tbl->tsiz);
39 }
40
41
42 unsigned long
43 lu_shash(s) /* hash a nul-terminated string */
44 char *s;
45 {
46 static unsigned char shuffle[256] = {
47 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
48 191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
49 126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
50 61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
51 252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
52 187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
53 122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
54 57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
55 248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
56 183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
57 118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
58 53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
59 244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
60 179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
61 114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
62 49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
63 240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
64 175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
65 110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
66 45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
67 236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
68 171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
69 106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
70 41, 198, 99
71 };
72 register int i = 0;
73 register unsigned long h = 0;
74 register unsigned char *t = (unsigned char *)s;
75
76 while (*t)
77 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
78
79 return(h);
80 }
81
82
83 LUENT *
84 lu_find(tbl, key) /* find a table entry */
85 register LUTAB *tbl;
86 char *key;
87 {
88 unsigned long hval;
89 int i, n;
90 register int ndx;
91 register LUENT *le;
92 /* look up object */
93 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
94 return(NULL);
95 hval = (*tbl->hashf)(key);
96 tryagain:
97 ndx = hval % tbl->tsiz;
98 for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
99 le = &tbl->tabl[ndx];
100 if (le->key == NULL) {
101 le->hval = hval;
102 return(le);
103 }
104 if (le->hval == hval &&
105 (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
106 return(le);
107 }
108 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
109 ndx = ndx % tbl->tsiz;
110 }
111 /* table is full, reallocate */
112 le = tbl->tabl;
113 ndx = tbl->tsiz;
114 i = tbl->ndel;
115 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
116 tbl->tabl = le;
117 tbl->tsiz = ndx;
118 tbl->ndel = i;
119 return(NULL);
120 }
121 /*
122 * The following code may fail if the user has reclaimed many
123 * deleted entries and the system runs out of memory in a
124 * recursive call to lu_find().
125 */
126 while (ndx--)
127 if (le[ndx].key != NULL) {
128 if (le[ndx].data != NULL)
129 *lu_find(tbl,le[ndx].key) = le[ndx];
130 else if (tbl->freek != NULL)
131 (*tbl->freek)(le[ndx].key);
132 }
133 free((void *)le);
134 goto tryagain; /* should happen only once! */
135 }
136
137
138 void
139 lu_delete(tbl, key) /* delete a table entry */
140 register LUTAB *tbl;
141 char *key;
142 {
143 register LUENT *le;
144
145 if ((le = lu_find(tbl, key)) == NULL)
146 return;
147 if (le->key == NULL || le->data == NULL)
148 return;
149 if (tbl->freed != NULL)
150 (*tbl->freed)(le->data);
151 le->data = NULL;
152 tbl->ndel++;
153 }
154
155
156 int
157 lu_doall(tbl, f) /* loop through all valid table entries */
158 register LUTAB *tbl;
159 int (*f)();
160 {
161 int rval = 0;
162 register LUENT *tp;
163
164 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
165 if (tp->data != NULL) {
166 if (f != NULL)
167 rval += (*f)(tp);
168 else
169 rval++;
170 }
171 return(rval);
172 }
173
174
175 void
176 lu_done(tbl) /* free table and contents */
177 register LUTAB *tbl;
178 {
179 register LUENT *tp;
180
181 if (!tbl->tsiz)
182 return;
183 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
184 if (tp->key != NULL) {
185 if (tbl->freek != NULL)
186 (*tbl->freek)(tp->key);
187 if (tp->data != NULL && tbl->freed != NULL)
188 (*tbl->freed)(tp->data);
189 }
190 free((void *)tbl->tabl);
191 tbl->tabl = NULL;
192 tbl->tsiz = 0;
193 tbl->ndel = 0;
194 }
