root/radiance/ray/src/common/loadvars.c
Sat May 4 00:36:58 2019 UTC (4 years, 11 months ago) by greg
Diff to previous 2.15
Eliminated cases where stdin was being closed
Fri May 22 14:44:11 2015 UTC (8 years, 11 months ago) by greg
Changes since 2.14: +50 -37 lines
Diff to previous 2.14
Added prototypes
Wed Jul 30 10:11:06 2003 UTC (20 years, 9 months ago) by schorsch
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Diff to previous 2.13
Diff to previous 2.12
Sat Jun 7 12:50:20 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.11: +3 -1 lines
Changes since 2.8: +70 -10 lines
Thu Jul 9 10:47:59 1998 UTC (25 years, 9 months ago) by gwlarson
increased limit on continued lines
Thu Jun 4 13:29:27 1998 UTC (25 years, 11 months ago) by gwlarson
Changes since 2.6: +9 -6 lines
changed logic in printvars() to generate continued lines
Thu Mar 20 12:47:24 1997 UTC (27 years, 1 month ago) by greg
Changes since 2.5: +15 -17 lines
Thu Mar 20 12:29:20 1997 UTC (27 years, 1 month ago) by greg
replaced calls to exit() with calls to quit()
Fri Apr 19 09:09:28 1996 UTC (28 years ago) by greg
added declaration of fgetline()
Tue Jan 23 11:52:57 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.2: +5 -3 lines
fixed reaction to empty variable assignment
Wed Jan 17 15:45:16 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.1: +5 -5 lines
changed parameter to nvalue()
Tue Dec 12 14:00:48 1995 UTC (28 years, 4 months ago) by greg
