root/Development/ray/src/common/loadvars.c
Sat Jun 10 20:20:51 2023 UTC (2 years, 6 months ago) by greg
Diff to previous 2.20
fix: Now squeezes unquoted spaces across escaped newlines
Sat Jun 10 15:49:55 2023 UTC (2 years, 6 months ago) by greg
Changes since 2.19: +17 -1 lines
Diff to previous 2.19
feat(rad,ranimate): Improved handling of quoted strings for file names
Fri Jun 9 22:52:47 2023 UTC (2 years, 6 months ago) by greg
Changes since 2.18: +12 -5 lines
Diff to previous 2.18
fix: Preserve spaces in quoted strings
Mon Jun 5 16:32:42 2023 UTC (2 years, 6 months ago) by greg
Diff to previous 2.17
fix: Missed one "const"
Mon Jun 5 16:09:55 2023 UTC (2 years, 6 months ago) by greg
Diff to previous 2.16
fix: Updated with const char * type where appropriate
Sat May 4 00:36:58 2019 UTC (6 years, 7 months ago) by greg
Diff to previous 2.15
Eliminated cases where stdin was being closed
Fri May 22 14:44:11 2015 UTC (10 years, 6 months ago) by greg
Changes since 2.14: +50 -37 lines
Diff to previous 2.14
Added prototypes
Wed Jul 30 10:11:06 2003 UTC (22 years, 4 months ago) by schorsch
CVS Tags: rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Diff to previous 2.13
Sun Jul 27 22:12:01 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 2.12
Sat Jun 7 12:50:20 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 2.11: +3 -1 lines
Wed Apr 23 00:52:33 2003 UTC (22 years, 8 months ago) by greg
Tue Feb 25 02:47:21 2003 UTC (22 years, 9 months ago) by greg
Sat Feb 22 02:07:22 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.8: +70 -10 lines
Thu Jul 9 10:47:59 1998 UTC (27 years, 5 months ago) by gwlarson
increased limit on continued lines
Thu Jun 4 13:29:27 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 2.6: +9 -6 lines
changed logic in printvars() to generate continued lines
Thu Mar 20 12:47:24 1997 UTC (28 years, 9 months ago) by greg
Changes since 2.5: +15 -17 lines
Thu Mar 20 12:29:20 1997 UTC (28 years, 9 months ago) by greg
replaced calls to exit() with calls to quit()
Fri Apr 19 09:09:28 1996 UTC (29 years, 8 months ago) by greg
added declaration of fgetline()
Tue Jan 23 11:52:57 1996 UTC (29 years, 11 months ago) by greg
Changes since 2.2: +5 -3 lines
fixed reaction to empty variable assignment
Wed Jan 17 15:45:16 1996 UTC (29 years, 11 months ago) by greg
Changes since 2.1: +5 -5 lines
changed parameter to nvalue()
Tue Dec 12 14:00:48 1995 UTC (30 years ago) by greg
