--- ray/src/common/loadvars.c 1998/07/09 10:47:59 2.8 +++ ray/src/common/loadvars.c 2003/07/30 10:11:06 2.14 @@ -1,26 +1,25 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: loadvars.c,v 2.14 2003/07/30 10:11:06 schorsch Exp $"; #endif - /* * Routines for loading and checking variables from file. */ +#include "copyright.h" + #include +#include #include + +#include "standard.h" #include "vars.h" #define NOCHAR 127 /* constant for character to delete */ -#ifndef malloc -extern char *malloc(), *realloc(); -#endif - extern char *fgetline(); +void loadvars(rfname) /* load variables into vv from file */ char *rfname; { @@ -61,7 +60,7 @@ char *rfname; int setvariable(ass, mv) /* assign variable according to string */ register char *ass; -VARIABLE *(*mv)(); +VARIABLE *(*mv)(char*); { char varname[32]; int n; @@ -91,15 +90,15 @@ VARIABLE *(*mv)(); if (vp == NULL) return(-1); /* assign new value */ - if (i = vp->nass) { + if ( (i = vp->nass) ) { cp = vp->value; while (i--) while (*cp++) ; i = cp - vp->value; - vp->value = realloc(vp->value, i+n+1); + vp->value = (char *)realloc((void *)vp->value, i+n+1); } else - vp->value = malloc(n+1); + vp->value = (char *)malloc(n+1); if (vp->value == NULL) { perror(progname); quit(1); @@ -141,7 +140,7 @@ register int n; { register char *cp; - if (vval(vn) == NULL | n < 0 | n >= vdef(vn)) + if ((vval(vn) == NULL) | (n < 0) | (n >= vdef(vn))) return(NULL); cp = vval(vn); while (n--) @@ -151,6 +150,7 @@ register int n; } +void checkvalues() /* check assignments */ { register int i; @@ -161,6 +161,7 @@ checkvalues() /* check assignments */ } +void onevalue(vp) /* only one assignment for this variable */ register VARIABLE *vp; { @@ -176,6 +177,7 @@ register VARIABLE *vp; } +void catvalues(vp) /* concatenate variable values */ register VARIABLE *vp; { @@ -204,6 +206,7 @@ register char *tv, *cv; } +void boolvalue(vp) /* check boolean for legal values */ register VARIABLE *vp; { @@ -223,6 +226,7 @@ register VARIABLE *vp; } +void qualvalue(vp) /* check qualitative var. for legal values */ register VARIABLE *vp; { @@ -245,6 +249,7 @@ register VARIABLE *vp; } +void intvalue(vp) /* check integer variable for legal values */ register VARIABLE *vp; { @@ -257,6 +262,7 @@ register VARIABLE *vp; } +void fltvalue(vp) /* check float variable for legal values */ register VARIABLE *vp; { @@ -269,6 +275,7 @@ register VARIABLE *vp; } +void printvars(fp) /* print variable values */ register FILE *fp; {
