root/radiance/ray/src/common/loadbsdf.c
Fri Aug 12 23:55:00 2022 UTC (2 years, 9 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 3.13: +5 -5 lines
Diff to previous 3.13
fix(iso2klems): used solid angle, when projected SA needed, and integral factor
Revision 3.13 - (view) (download) (annotate) - [selected]
Sat Mar 27 17:50:18 2021 UTC (4 years, 1 month ago) by greg
Changes since 3.12: +7 -5 lines
Diff to previous 3.12
Thu May 14 19:20:13 2020 UTC (5 years ago) by greg
Changes since 3.11: +6 -1 lines
Diff to previous 3.11 , to selected 3.13
Added cumulative cache size limit (per loaded BSDF)
Tue Mar 22 03:56:17 2016 UTC (9 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2
Diff to previous 3.10 , to selected 3.13
Made error messages more consistent when library file not found
Sat Apr 25 19:08:29 2015 UTC (10 years ago) by greg
Changes since 3.9: +2 -2 lines
Diff to previous 3.9 , to selected 3.13
Fixed missing assignment of diffuse color
Sun Apr 5 01:32:01 2015 UTC (10 years, 1 month ago) by greg
Changes since 3.8: +10 -4 lines
Diff to previous 3.8 , to selected 3.13
Added color rendering to tensor tree and minor fixes to Klems color rendering
Sun Apr 21 21:36:23 2013 UTC (12 years, 1 month ago) by greg
Changes since 3.7: +3 -3 lines
Diff to previous 3.7 , to selected 3.13
Added pointer indirection to make error reporting in other languages simpler
Sun Sep 2 15:33:15 2012 UTC (12 years, 8 months ago) by greg
Changes since 3.6: +7 -3 lines
Diff to previous 3.6 , to selected 3.13
Wed May 2 16:28:45 2012 UTC (13 years ago) by greg
Changes since 3.5: +7 -7 lines
Diff to previous 3.5 , to selected 3.13
Fixed bug for matrix BSDFs with more than one phi angle around zenith
Thu Apr 28 00:24:43 2011 UTC (14 years ago) by greg
Changes since 3.4: +2 -2 lines
Diff to previous 3.4 , to selected 3.13
Removed debugging
Wed Apr 27 23:05:51 2011 UTC (14 years ago) by greg
Changes since 3.3: +2 -2 lines
Diff to previous 3.3 , to selected 3.13
First test of variable-res BSDFs
Sat Feb 19 23:42:09 2011 UTC (14 years, 3 months ago) by greg
Changes since 3.2: +3 -1 lines
Diff to previous 3.2 , to selected 3.13
Fixes to BSDF including blurring of angle boundaries
Sat Feb 19 01:48:59 2011 UTC (14 years, 3 months ago) by greg
Changes since 3.1: +28 -16 lines
Diff to previous 3.1 , to selected 3.13
Minor changes and fixes -- first working version of BSDF material
Fri Feb 18 02:41:55 2011 UTC (14 years, 3 months ago) by greg
Diff to selected 3.13
Minor fixes and adjustments
