--- ray/src/common/loadbsdf.c 2020/05/14 19:20:13 3.12 +++ ray/src/common/loadbsdf.c 2022/08/12 23:55:00 3.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: loadbsdf.c,v 3.12 2020/05/14 19:20:13 greg Exp $"; +static const char RCSid[] = "$Id: loadbsdf.c,v 3.14 2022/08/12 23:55:00 greg Exp $"; #endif /* * Simple interface for loading BSDF, Radiance-specific search @@ -58,8 +58,8 @@ loadBSDF(char *fname) /* simple checks */ checkDF(sd->name, sd->rLambFront.cieY, sd->rf, "front reflection"); checkDF(sd->name, sd->rLambBack.cieY, sd->rb, "rear reflection"); - checkDF(sd->name, sd->tLamb.cieY, sd->tf, "front transmission"); - checkDF(sd->name, sd->tLamb.cieY, sd->tb, "back transmission"); + checkDF(sd->name, sd->tLambFront.cieY, sd->tf, "front transmission"); + checkDF(sd->name, sd->tLambBack.cieY, sd->tb, "back transmission"); #ifdef DEBUG { float rgb[3]; @@ -68,19 +68,21 @@ ccy2rgb(&sd->rLambFront.spec, sd->rLambFront.cieY, rgb fprintf(stderr, "Front diffuse RGB: %.4f %.4f %.4f\n", rgb[0], rgb[1], rgb[2]); ccy2rgb(&sd->rLambBack.spec, sd->rLambBack.cieY, rgb); fprintf(stderr, "Back diffuse RGB: %.4f %.4f %.4f\n", rgb[0], rgb[1], rgb[2]); -ccy2rgb(&sd->tLamb.spec, sd->tLamb.cieY, rgb); -fprintf(stderr, "Diffuse RGB transmittance: %.4f %.4f %.4f\n", rgb[0], rgb[1], rgb[2]); +ccy2rgb(&sd->tLambFront.spec, sd->tLamb.cieY, rgb); +fprintf(stderr, "Front diffuse RGB transmittance: %.4f %.4f %.4f\n", rgb[0], rgb[1], rgb[2]); +ccy2rgb(&sd->tLambBack.spec, sd->tLamb.cieY, rgb); +fprintf(stderr, "Back diffuse RGB transmittance: %.4f %.4f %.4f\n", rgb[0], rgb[1], rgb[2]); if (sd->rf) -fprintf(stderr, "Maximum direct hemispherical front reflection: %.3f%%\n", +fprintf(stderr, "Maximum direct hemispherical front reflection (less diffuse): %.3f%%\n", sd->rf->maxHemi*100.); if (sd->rb) -fprintf(stderr, "Maximum direct hemispherical back reflection: %.3f%%\n", +fprintf(stderr, "Maximum direct hemispherical back reflection (less diffuse): %.3f%%\n", sd->rb->maxHemi*100.); if (sd->tf) -fprintf(stderr, "Maximum direct hemispherical front transmission: %.3f%%\n", +fprintf(stderr, "Maximum direct hemispherical front transmission (less diffuse): %.3f%%\n", sd->tf->maxHemi*100.); if (sd->tb) -fprintf(stderr, "Maximum direct hemispherical back transmission: %.3f%%\n", +fprintf(stderr, "Maximum direct hemispherical back transmission (less diffuse): %.3f%%\n", sd->tb->maxHemi*100.); } #endif
