--- ray/src/common/loadbsdf.c 2012/05/02 16:28:45 3.6 +++ ray/src/common/loadbsdf.c 2015/04/25 19:08:29 3.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: loadbsdf.c,v 3.6 2012/05/02 16:28:45 greg Exp $"; +static const char RCSid[] = "$Id: loadbsdf.c,v 3.10 2015/04/25 19:08:29 greg Exp $"; #endif /* * Simple interface for loading BSDF, Radiance-specific search @@ -15,9 +15,9 @@ char * transSDError(SDError ec) { if (!SDerrorDetail[0]) - return(strcpy(errmsg, SDerrorEnglish[ec])); + return(strcpy(errmsg, SDerrorList[ec])); - sprintf(errmsg, "%s: %s", SDerrorEnglish[ec], SDerrorDetail); + sprintf(errmsg, "%s: %s", SDerrorList[ec], SDerrorDetail); return(errmsg); } @@ -58,12 +58,18 @@ loadBSDF(char *fname) /* simple checks */ checkDF(sd->name, sd->rLambFront.cieY, sd->rf, "front reflection"); checkDF(sd->name, sd->rLambBack.cieY, sd->rb, "rear reflection"); - checkDF(sd->name, sd->tLamb.cieY, sd->tf, "transmission"); -#if 0 + checkDF(sd->name, sd->tLamb.cieY, sd->tf, "front transmission"); + checkDF(sd->name, sd->tLamb.cieY, sd->tb, "back transmission"); +#ifdef DEBUG +{ +float rgb[3]; fprintf(stderr, "Loaded BSDF '%s' (file \"%s\")\n", sd->name, pname); -fprintf(stderr, "Front diffuse reflectance: %.3f%%\n", sd->rLambFront.cieY*100.); -fprintf(stderr, "Back diffuse reflectance: %.3f%%\n", sd->rLambBack.cieY*100.); -fprintf(stderr, "Diffuse transmittance: %.3f%%\n", sd->tLamb.cieY*100.); +ccy2rgb(&sd->rLambFront.spec, sd->rLambFront.cieY, rgb); +fprintf(stderr, "Front diffuse RGB: %.4f %.4f %.4f\n", rgb[0], rgb[1], rgb[2]); +ccy2rgb(&sd->rLambBack.spec, sd->rLambBack.cieY, rgb); +fprintf(stderr, "Back diffuse RGB: %.4f %.4f %.4f\n", rgb[0], rgb[1], rgb[2]); +ccy2rgb(&sd->tLamb.spec, sd->tLamb.cieY, rgb); +fprintf(stderr, "Diffuse RGB transmittance: %.4f %.4f %.4f\n", rgb[0], rgb[1], rgb[2]); if (sd->rf) fprintf(stderr, "Maximum direct hemispherical front reflection: %.3f%%\n", sd->rf->maxHemi*100.); @@ -71,8 +77,12 @@ if (sd->rb) fprintf(stderr, "Maximum direct hemispherical back reflection: %.3f%%\n", sd->rb->maxHemi*100.); if (sd->tf) -fprintf(stderr, "Maximum direct hemispherical transmission: %.3f%%\n", +fprintf(stderr, "Maximum direct hemispherical front transmission: %.3f%%\n", sd->tf->maxHemi*100.); +if (sd->tb) +fprintf(stderr, "Maximum direct hemispherical back transmission: %.3f%%\n", +sd->tb->maxHemi*100.); +} #endif SDretainSet = SDretainAll; /* keep data in core */ return(sd);
