root/radiance/ray/src/common/lamps.c
Mon Feb 18 23:35:51 2008 UTC (16 years, 2 months ago) by greg
CVS Tags: HEAD, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Removed unnecessary declaration
Sun Jun 8 12:03:09 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.8: +10 -6 lines
Sat Jun 7 12:50:20 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.5: +62 -7 lines
Mon Oct 16 09:21:46 1995 UTC (28 years, 6 months ago) by greg
added dependency on color.h to lamps.o for cie_rgb() macro
Wed Mar 1 10:40:18 1995 UTC (29 years, 2 months ago) by greg
changed fropen() call to frlibopen()
Mon Aug 23 10:12:43 1993 UTC (30 years, 8 months ago) by greg
Changes since 2.2: +6 -6 lines
added original xyY to end of color array
Tue Nov 10 10:29:22 1992 UTC (31 years, 5 months ago) by greg
Changes since 2.1: +2 -1 lines
Diff to previous 2.1
fixed bug for free() routines that touch contents
Tue Nov 12 16:54:46 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.3
Fri Dec 14 13:12:28 1990 UTC (33 years, 4 months ago) by greg
Diff to previous 1.2
changed return value of loadlamps() to 0 if no lamps loaded
Fri Dec 14 12:29:41 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.1: +18 -0 lines
Diff to previous 1.1
added freelamps()
Sat Dec 8 09:28:16 1990 UTC (33 years, 4 months ago) by greg
