| 1 |
/* Copyright (c) 1990 Regents of the University of California */ |
| 2 |
| 3 |
#ifndef lint |
| 4 |
static char SCCSid[] = "$SunId$ LBL"; |
| 5 |
#endif |
| 6 |
| 7 |
| 8 |
* Load lamp data. |
| 9 |
| 10 |
| 11 |
#include <stdio.h> |
| 12 |
#include <ctype.h> |
| 13 |
#include "color.h" |
| 14 |
| 15 |
extern char *eindex(), *expsave(), *malloc(); |
| 16 |
extern FILE *frlibopen(); |
| 17 |
| 18 |
typedef struct lamp { |
| 19 |
char *pattern; /* search pattern */ |
| 20 |
float *color; /* pointer to lamp value */ |
| 21 |
struct lamp *next; /* next lamp in list */ |
| 22 |
} LAMP; /* a lamp entry */ |
| 23 |
| 24 |
static LAMP *lamps = NULL; /* lamp list */ |
| 25 |
| 26 |
| 27 |
float * |
| 28 |
matchlamp(s) /* see if string matches any lamp */ |
| 29 |
char *s; |
| 30 |
| 31 |
register LAMP *lp; |
| 32 |
| 33 |
for (lp = lamps; lp != NULL; lp = lp->next) { |
| 34 |
expset(lp->pattern); |
| 35 |
if (eindex(s) != NULL) |
| 36 |
return(lp->color); |
| 37 |
| 38 |
return(NULL); |
| 39 |
| 40 |
| 41 |
| 42 |
loadlamps(file) /* load lamp type file */ |
| 43 |
char *file; |
| 44 |
| 45 |
LAMP *lastp; |
| 46 |
| 47 |
FILE *fp; |
| 48 |
float xyz[3]; |
| 49 |
char buf[128], str[128]; |
| 50 |
register char *cp1, *cp2; |
| 51 |
| 52 |
if ((fp = frlibopen(file)) == NULL) |
| 53 |
return(0); |
| 54 |
lastp = NULL; |
| 55 |
while (fgets(buf, sizeof(buf), fp) != NULL) { |
| 56 |
/* work on a copy of buffer */ |
| 57 |
strcpy(str, buf); |
| 58 |
/* get pattern for this entry */ |
| 59 |
for (cp1 = str; isspace(*cp1); cp1++) |
| 60 |
| 61 |
if (!*cp1 || *cp1 == '#') |
| 62 |
continue; |
| 63 |
for (cp2 = cp1+1; *cp2; cp2++) |
| 64 |
if (*cp2 == *cp1 && cp2[-1] != '\\') |
| 65 |
break; |
| 66 |
if (!*cp2) { |
| 67 |
cp1 = "unclosed pattern"; |
| 68 |
goto fmterr; |
| 69 |
| 70 |
cp1++; *cp2++ = '\0'; |
| 71 |
if (ecompile(cp1, 1, 0) < 0) { |
| 72 |
cp1 = "bad regular expression"; |
| 73 |
goto fmterr; |
| 74 |
| 75 |
if ((lp = (LAMP *)malloc(sizeof(LAMP))) == NULL) |
| 76 |
goto memerr; |
| 77 |
if ((lp->pattern = expsave()) == NULL) |
| 78 |
goto memerr; |
| 79 |
/* get specification */ |
| 80 |
for (cp1 = cp2; isspace(*cp1); cp1++) |
| 81 |
| 82 |
if (!isdigit(*cp1) && *cp1 != '.' && *cp1 != '(') { |
| 83 |
cp1 = "missing lamp specification"; |
| 84 |
goto fmterr; |
| 85 |
| 86 |
if (*cp1 == '(') { /* find alias */ |
| 87 |
for (cp2 = ++cp1; *cp2; cp2++) |
| 88 |
if (*cp2 == ')' && cp2[-1] != '\\') |
| 89 |
break; |
| 90 |
*cp2 = '\0'; |
| 91 |
if ((lp->color = matchlamp(cp1)) == NULL) { |
| 92 |
cp1 = "unmatched alias"; |
| 93 |
goto fmterr; |
| 94 |
| 95 |
} else { /* or read specificaion */ |
| 96 |
if ((lp->color=(float *)malloc(6*sizeof(float)))==NULL) |
| 97 |
goto memerr; |
| 98 |
if (sscanf(cp1, "%f %f %f", &lp->color[3], & |
| 99 |
lp->color[4], &lp->color[5]) != 3) { |
| 100 |
cp1 = "bad lamp data"; |
| 101 |
goto fmterr; |
| 102 |
| 103 |
/* convert xyY to XYZ */ |
| 104 |
xyz[1] = lp->color[5]; |
| 105 |
xyz[0] = lp->color[3]/lp->color[4] * xyz[1]; |
| 106 |
xyz[2] = xyz[1]*(1./lp->color[4] - 1.) - xyz[0]; |
| 107 |
/* XYZ to RGB */ |
| 108 |
cie_rgb(lp->color, xyz); |
| 109 |
| 110 |
if (lastp == NULL) |
| 111 |
lamps = lp; |
| 112 |
else |
| 113 |
lastp->next = lp; |
| 114 |
lp->next = NULL; |
| 115 |
lastp = lp; |
| 116 |
| 117 |
fclose(fp); |
| 118 |
return(lastp != NULL); |
| 119 |
memerr: |
| 120 |
fputs("Out of memory in loadlamps\n", stderr); |
| 121 |
return(-1); |
| 122 |
fmterr: |
| 123 |
fputs(buf, stderr); |
| 124 |
fprintf(stderr, "%s: %s\n", file, cp1); |
| 125 |
return(-1); |
| 126 |
| 127 |
| 128 |
| 129 |
freelamps() /* free our lamps list */ |
| 130 |
| 131 |
register LAMP *lp1, *lp2; |
| 132 |
| 133 |
for (lp1 = lamps; lp1 != NULL; lp1 = lp2) { |
| 134 |
free(lp1->pattern); |
| 135 |
if (lp1->color != NULL) { |
| 136 |
for (lp2 = lp1->next; lp2 != NULL; lp2 = lp2->next) |
| 137 |
if (lp2->color == lp1->color) |
| 138 |
lp2->color = NULL; |
| 139 |
free((char *)lp1->color); |
| 140 |
| 141 |
lp2 = lp1->next; |
| 142 |
free((char *)lp1); |
| 143 |
| 144 |
lamps = NULL; |
| 145 |
