| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: lamps.c,v 2.10 2008/02/18 23:35:51 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Load lamp data.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <ctype.h>
| 11 |
| 12 |
#include "standard.h"
| 13 |
#include "paths.h"
| 14 |
#include "color.h"
| 15 |
| 16 |
extern char *eindex(), *expsave();
| 17 |
| 18 |
typedef struct lamp {
| 19 |
char *pattern; /* search pattern */
| 20 |
float *color; /* pointer to lamp value */
| 21 |
struct lamp *next; /* next lamp in list */
| 22 |
} LAMP; /* a lamp entry */
| 23 |
| 24 |
static LAMP *lamps = NULL; /* lamp list */
| 25 |
| 26 |
| 27 |
float *
| 28 |
matchlamp( /* see if string matches any lamp */
| 29 |
char *s
| 30 |
| 31 |
| 32 |
register LAMP *lp;
| 33 |
| 34 |
for (lp = lamps; lp != NULL; lp = lp->next) {
| 35 |
expset(lp->pattern);
| 36 |
if (eindex(s) != NULL)
| 37 |
return(lp->color);
| 38 |
| 39 |
return(NULL);
| 40 |
| 41 |
| 42 |
| 43 |
int
| 44 |
loadlamps( /* load lamp type file */
| 45 |
char *file
| 46 |
| 47 |
| 48 |
LAMP *lastp;
| 49 |
register LAMP *lp;
| 50 |
FILE *fp;
| 51 |
float xyz[3];
| 52 |
char buf[128], str[128];
| 53 |
register char *cp1, *cp2;
| 54 |
| 55 |
if ((fp = frlibopen(file)) == NULL)
| 56 |
return(0);
| 57 |
lastp = NULL;
| 58 |
while (fgets(buf, sizeof(buf), fp) != NULL) {
| 59 |
/* work on a copy of buffer */
| 60 |
strcpy(str, buf);
| 61 |
/* get pattern for this entry */
| 62 |
for (cp1 = str; isspace(*cp1); cp1++)
| 63 |
| 64 |
if (!*cp1 || *cp1 == '#')
| 65 |
continue;
| 66 |
for (cp2 = cp1+1; *cp2; cp2++)
| 67 |
if (*cp2 == *cp1 && cp2[-1] != '\\')
| 68 |
break;
| 69 |
if (!*cp2) {
| 70 |
cp1 = "unclosed pattern";
| 71 |
goto fmterr;
| 72 |
| 73 |
cp1++; *cp2++ = '\0';
| 74 |
if (ecompile(cp1, 1, 0) < 0) {
| 75 |
cp1 = "bad regular expression";
| 76 |
goto fmterr;
| 77 |
| 78 |
if ((lp = (LAMP *)malloc(sizeof(LAMP))) == NULL)
| 79 |
goto memerr;
| 80 |
if ((lp->pattern = expsave()) == NULL)
| 81 |
goto memerr;
| 82 |
/* get specification */
| 83 |
for (cp1 = cp2; isspace(*cp1); cp1++)
| 84 |
| 85 |
if (!isdigit(*cp1) && *cp1 != '.' && *cp1 != '(') {
| 86 |
cp1 = "missing lamp specification";
| 87 |
goto fmterr;
| 88 |
| 89 |
if (*cp1 == '(') { /* find alias */
| 90 |
for (cp2 = ++cp1; *cp2; cp2++)
| 91 |
if (*cp2 == ')' && cp2[-1] != '\\')
| 92 |
break;
| 93 |
*cp2 = '\0';
| 94 |
if ((lp->color = matchlamp(cp1)) == NULL) {
| 95 |
cp1 = "unmatched alias";
| 96 |
goto fmterr;
| 97 |
| 98 |
} else { /* or read specificaion */
| 99 |
if ((lp->color=(float *)malloc(6*sizeof(float)))==NULL)
| 100 |
goto memerr;
| 101 |
if (sscanf(cp1, "%f %f %f", &lp->color[3], &
| 102 |
lp->color[4], &lp->color[5]) != 3) {
| 103 |
cp1 = "bad lamp data";
| 104 |
goto fmterr;
| 105 |
| 106 |
/* convert xyY to XYZ */
| 107 |
xyz[1] = lp->color[5];
| 108 |
xyz[0] = lp->color[3]/lp->color[4] * xyz[1];
| 109 |
xyz[2] = xyz[1]*(1./lp->color[4] - 1.) - xyz[0];
| 110 |
/* XYZ to RGB */
| 111 |
cie_rgb(lp->color, xyz);
| 112 |
| 113 |
if (lastp == NULL)
| 114 |
lamps = lp;
| 115 |
else
| 116 |
lastp->next = lp;
| 117 |
lp->next = NULL;
| 118 |
lastp = lp;
| 119 |
| 120 |
fclose(fp);
| 121 |
return(lastp != NULL);
| 122 |
memerr:
| 123 |
fputs("Out of memory in loadlamps\n", stderr);
| 124 |
return(-1);
| 125 |
fmterr:
| 126 |
fputs(buf, stderr);
| 127 |
fprintf(stderr, "%s: %s\n", file, cp1);
| 128 |
return(-1);
| 129 |
| 130 |
| 131 |
| 132 |
void
| 133 |
freelamps(void) /* free our lamps list */
| 134 |
| 135 |
register LAMP *lp1, *lp2;
| 136 |
| 137 |
for (lp1 = lamps; lp1 != NULL; lp1 = lp2) {
| 138 |
free(lp1->pattern);
| 139 |
if (lp1->color != NULL) {
| 140 |
for (lp2 = lp1->next; lp2 != NULL; lp2 = lp2->next)
| 141 |
if (lp2->color == lp1->color)
| 142 |
lp2->color = NULL;
| 143 |
free((void *)lp1->color);
| 144 |
| 145 |
lp2 = lp1->next;
| 146 |
free((void *)lp1);
| 147 |
| 148 |
lamps = NULL;
| 149 |
