root/radiance/ray/src/common/lamps.c
Revision: 2.8
Committed: Sat Jun 7 12:50:20 2003 UTC (22 years, 2 months ago) by schorsch
2 static const char RCSid[] = "$Id: lamps.c,v 2.7 2003/02/25 02:47:21 greg Exp $";
5 * Load lamp data.
6 */
7
8 #include "copyright.h"
9
10 #include <stdio.h>
11 #include <stdlib.h>
12 #include <ctype.h>
13
14 #include "standard.h"
15 #include "color.h"
16
17 extern char *eindex(), *expsave();
18 extern FILE *frlibopen();
19
20 typedef struct lamp {
21 char *pattern; /* search pattern */
22 float *color; /* pointer to lamp value */
23 struct lamp *next; /* next lamp in list */
24 } LAMP; /* a lamp entry */
25
26 static LAMP *lamps = NULL; /* lamp list */
27
28
29 float *
30 matchlamp(s) /* see if string matches any lamp */
31 char *s;
32 {
33 register LAMP *lp;
34
35 for (lp = lamps; lp != NULL; lp = lp->next) {
36 expset(lp->pattern);
37 if (eindex(s) != NULL)
38 return(lp->color);
39 }
40 return(NULL);
41 }
42
43
44 loadlamps(file) /* load lamp type file */
45 char *file;
46 {
47 LAMP *lastp;
48 register LAMP *lp;
49 FILE *fp;
50 float xyz[3];
51 char buf[128], str[128];
52 register char *cp1, *cp2;
53
54 if ((fp = frlibopen(file)) == NULL)
55 return(0);
56 lastp = NULL;
57 while (fgets(buf, sizeof(buf), fp) != NULL) {
58 /* work on a copy of buffer */
59 strcpy(str, buf);
60 /* get pattern for this entry */
61 for (cp1 = str; isspace(*cp1); cp1++)
62 ;
63 if (!*cp1 || *cp1 == '#')
64 continue;
65 for (cp2 = cp1+1; *cp2; cp2++)
66 if (*cp2 == *cp1 && cp2[-1] != '\\')
67 break;
68 if (!*cp2) {
69 cp1 = "unclosed pattern";
70 goto fmterr;
71 }
72 cp1++; *cp2++ = '\0';
73 if (ecompile(cp1, 1, 0) < 0) {
74 cp1 = "bad regular expression";
75 goto fmterr;
76 }
77 if ((lp = (LAMP *)malloc(sizeof(LAMP))) == NULL)
78 goto memerr;
79 if ((lp->pattern = expsave()) == NULL)
80 goto memerr;
81 /* get specification */
82 for (cp1 = cp2; isspace(*cp1); cp1++)
83 ;
84 if (!isdigit(*cp1) && *cp1 != '.' && *cp1 != '(') {
85 cp1 = "missing lamp specification";
86 goto fmterr;
87 }
88 if (*cp1 == '(') { /* find alias */
89 for (cp2 = ++cp1; *cp2; cp2++)
90 if (*cp2 == ')' && cp2[-1] != '\\')
91 break;
92 *cp2 = '\0';
93 if ((lp->color = matchlamp(cp1)) == NULL) {
94 cp1 = "unmatched alias";
95 goto fmterr;
96 }
97 } else { /* or read specificaion */
98 if ((lp->color=(float *)malloc(6*sizeof(float)))==NULL)
99 goto memerr;
100 if (sscanf(cp1, "%f %f %f", &lp->color[3], &
101 lp->color[4], &lp->color[5]) != 3) {
102 cp1 = "bad lamp data";
103 goto fmterr;
104 }
105 /* convert xyY to XYZ */
106 xyz[1] = lp->color[5];
107 xyz[0] = lp->color[3]/lp->color[4] * xyz[1];
108 xyz[2] = xyz[1]*(1./lp->color[4] - 1.) - xyz[0];
109 /* XYZ to RGB */
110 cie_rgb(lp->color, xyz);
111 }
112 if (lastp == NULL)
113 lamps = lp;
114 else
115 lastp->next = lp;
116 lp->next = NULL;
117 lastp = lp;
118 }
119 fclose(fp);
120 return(lastp != NULL);
121 memerr:
122 fputs("Out of memory in loadlamps\n", stderr);
123 return(-1);
124 fmterr:
125 fputs(buf, stderr);
126 fprintf(stderr, "%s: %s\n", file, cp1);
127 return(-1);
128 }
129
130
131 freelamps() /* free our lamps list */
132 {
133 register LAMP *lp1, *lp2;
134
135 for (lp1 = lamps; lp1 != NULL; lp1 = lp2) {
136 free(lp1->pattern);
137 if (lp1->color != NULL) {
138 for (lp2 = lp1->next; lp2 != NULL; lp2 = lp2->next)
139 if (lp2->color == lp1->color)
140 lp2->color = NULL;
141 free((void *)lp1->color);
142 }
143 lp2 = lp1->next;
144 free((void *)lp1);
145 }
146 lamps = NULL;
147 }
