root/radiance/ray/src/common/lamps.c
Revision: 1.1
Committed: Sat Dec 8 09:28:16 1990 UTC (34 years, 8 months ago) by greg
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Load lamp data.
9 */
10
11 #include <stdio.h>
12 #include <ctype.h>
13
14 extern char *eindex(), *expsave(), *malloc();
15 extern FILE *fropen();
16
17 typedef struct lamp {
18 char *pattern; /* search pattern */
19 float *color; /* pointer to lamp value */
20 struct lamp *next; /* next lamp in list */
21 } LAMP; /* a lamp entry */
22
23 static LAMP *lamps = NULL; /* lamp list */
24
25
26 float *
27 matchlamp(s) /* see if string matches any lamp */
28 char *s;
29 {
30 register LAMP *lp;
31
32 for (lp = lamps; lp != NULL; lp = lp->next) {
33 expset(lp->pattern);
34 if (eindex(s) != NULL)
35 return(lp->color);
36 }
37 return(NULL);
38 }
39
40
41 loadlamps(file) /* load lamp type file */
42 char *file;
43 {
44 LAMP *lastp;
45 register LAMP *lp;
46 FILE *fp;
47 float xyz[3];
48 char buf[128], str[128];
49 register char *cp1, *cp2;
50
51 if ((fp = fropen(file)) == NULL)
52 return(0);
53 lastp = NULL;
54 while (fgets(buf, sizeof(buf), fp) != NULL) {
55 /* work on a copy of buffer */
56 strcpy(str, buf);
57 /* get pattern for this entry */
58 for (cp1 = str; isspace(*cp1); cp1++)
59 ;
60 if (!*cp1 || *cp1 == '#')
61 continue;
62 for (cp2 = cp1+1; *cp2; cp2++)
63 if (*cp2 == *cp1 && cp2[-1] != '\\')
64 break;
65 if (!*cp2) {
66 cp1 = "unclosed pattern";
67 goto fmterr;
68 }
69 cp1++; *cp2++ = '\0';
70 if (ecompile(cp1, 1, 0) < 0) {
71 cp1 = "bad regular expression";
72 goto fmterr;
73 }
74 if ((lp = (LAMP *)malloc(sizeof(LAMP))) == NULL)
75 goto memerr;
76 if ((lp->pattern = expsave()) == NULL)
77 goto memerr;
78 /* get specification */
79 for (cp1 = cp2; isspace(*cp1); cp1++)
80 ;
81 if (!isdigit(*cp1) && *cp1 != '.' && *cp1 != '(') {
82 cp1 = "missing lamp specification";
83 goto fmterr;
84 }
85 if (*cp1 == '(') { /* find alias */
86 for (cp2 = ++cp1; *cp2; cp2++)
87 if (*cp2 == ')' && cp2[-1] != '\\')
88 break;
89 *cp2 = '\0';
90 if ((lp->color = matchlamp(cp1)) == NULL) {
91 cp1 = "unmatched alias";
92 goto fmterr;
93 }
94 } else { /* or read specificaion */
95 if ((lp->color=(float *)malloc(3*sizeof(float)))==NULL)
96 goto memerr;
97 if (sscanf(cp1, "%f %f %f", &lp->color[0], &
98 lp->color[1], &lp->color[2]) != 3) {
99 cp1 = "bad lamp data";
100 goto fmterr;
101 }
102 /* convert xyY to XYZ */
103 xyz[1] = lp->color[2];
104 xyz[0] = lp->color[0]/lp->color[1] * xyz[1];
105 xyz[2] = xyz[1]*(1./lp->color[1] - 1.) - xyz[0];
106 /* XYZ to RGB */
107 cie_rgb(lp->color, xyz);
108 }
109 if (lastp == NULL)
110 lamps = lp;
111 else
112 lastp->next = lp;
113 lp->next = NULL;
114 lastp = lp;
115 }
116 fclose(fp);
117 return(1);
118 memerr:
119 fputs("Out of memory in loadlamps\n", stderr);
120 return(-1);
121 fmterr:
122 fputs(buf, stderr);
123 fprintf(stderr, "%s: %s\n", file, cp1);
124 return(-1);
125 }
