--- ray/src/common/lamps.c 1990/12/14 13:12:28 1.3
+++ ray/src/common/lamps.c 2003/02/22 02:07:22 2.6
@@ -1,18 +1,74 @@
-/* Copyright (c) 1990 Regents of the University of California */
#ifndef lint
-static char SCCSid[] = "$SunId$ LBL";
+static const char RCSid[] = "$Id: lamps.c,v 2.6 2003/02/22 02:07:22 greg Exp $";
#endif
* Load lamp data.
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
#include
+#include
#include
+#include "color.h"
-extern char *eindex(), *expsave(), *malloc();
-extern FILE *fropen();
+extern char *eindex(), *expsave();
+extern FILE *frlibopen();
typedef struct lamp {
char *pattern; /* search pattern */
@@ -48,7 +104,7 @@ char *file;
char buf[128], str[128];
register char *cp1, *cp2;
- if ((fp = fropen(file)) == NULL)
+ if ((fp = frlibopen(file)) == NULL)
return(0);
lastp = NULL;
while (fgets(buf, sizeof(buf), fp) != NULL) {
@@ -92,17 +148,17 @@ char *file;
goto fmterr;
} else { /* or read specificaion */
- if ((lp->color=(float *)malloc(3*sizeof(float)))==NULL)
+ if ((lp->color=(float *)malloc(6*sizeof(float)))==NULL)
goto memerr;
- if (sscanf(cp1, "%f %f %f", &lp->color[0], &
- lp->color[1], &lp->color[2]) != 3) {
+ if (sscanf(cp1, "%f %f %f", &lp->color[3], &
+ lp->color[4], &lp->color[5]) != 3) {
cp1 = "bad lamp data";
goto fmterr;
/* convert xyY to XYZ */
- xyz[1] = lp->color[2];
- xyz[0] = lp->color[0]/lp->color[1] * xyz[1];
- xyz[2] = xyz[1]*(1./lp->color[1] - 1.) - xyz[0];
+ xyz[1] = lp->color[5];
+ xyz[0] = lp->color[3]/lp->color[4] * xyz[1];
+ xyz[2] = xyz[1]*(1./lp->color[4] - 1.) - xyz[0];
/* XYZ to RGB */
cie_rgb(lp->color, xyz);
@@ -129,15 +185,16 @@ freelamps() /* free our lamps list */
register LAMP *lp1, *lp2;
- for (lp1 = lamps; lp1 != NULL; lp1 = lp1->next) {
+ for (lp1 = lamps; lp1 != NULL; lp1 = lp2) {
free(lp1->pattern);
if (lp1->color != NULL) {
for (lp2 = lp1->next; lp2 != NULL; lp2 = lp2->next)
if (lp2->color == lp1->color)
lp2->color = NULL;
- free((char *)lp1->color);
+ free((void *)lp1->color);
- free((char *)lp1);
+ lp2 = lp1->next;
+ free((void *)lp1);
lamps = NULL;
