root/radiance/ray/src/common/invmat4.c
Revision: 2.3
Committed: Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 2.2: +1 -56 lines
5 * invmat4 - computes the inverse of mat into inverse. Returns 1
6 * if there exists an inverse, 0 otherwise. It uses Gaussian Elimination
7 * method.
8 */
9
10 #include "copyright.h"
11
12 #include "mat4.h"
13
14
15 #define ABS(x) ((x)>=0 ? (x) : -(x))
16
17 #define SWAP(a,b,t) (t=a,a=b,b=t)
18
19
20 int
21 invmat4(inverse, mat)
22 MAT4 inverse, mat;
23 {
24 MAT4 m4tmp;
25 register int i,j,k;
26 register double temp;
27
28 copymat4(m4tmp, mat);
29 /* set inverse to identity */
30 setident4(inverse);
31
32 for(i = 0; i < 4; i++) {
33 /* Look for row with largest pivot and swap rows */
34 temp = FTINY; j = -1;
35 for(k = i; k < 4; k++)
36 if(ABS(m4tmp[k][i]) > temp) {
37 temp = ABS(m4tmp[k][i]);
38 j = k;
39 }
40 if(j == -1) /* No replacing row -> no inverse */
41 return(0);
42 if (j != i)
43 for(k = 0; k < 4; k++) {
44 SWAP(m4tmp[i][k],m4tmp[j][k],temp);
45 SWAP(inverse[i][k],inverse[j][k],temp);
46 }
47
48 temp = m4tmp[i][i];
49 for(k = 0; k < 4; k++) {
50 m4tmp[i][k] /= temp;
51 inverse[i][k] /= temp;
52 }
53 for(j = 0; j < 4; j++) {
54 if(j != i) {
55 temp = m4tmp[j][i];
56 for(k = 0; k < 4; k++) {
57 m4tmp[j][k] -= m4tmp[i][k]*temp;
58 inverse[j][k] -= inverse[i][k]*temp;
59 }
60 }
61 }
62 }
63 return(1);
64 }
