root/radiance/ray/src/common/invmat4.c
Revision: 2.1
Committed: Tue Apr 12 15:20:48 1994 UTC (31 years, 4 months ago) by greg
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * invmat4 - computes the inverse of mat into inverse. Returns 1
9 * if there exists an inverse, 0 otherwise. It uses Gaussian Elimination
10 * method.
11 */
12
13 #include "mat4.h"
14
15
16 #define ABS(x) ((x)>=0 ? (x) : -(x))
17
18 #define SWAP(a,b,t) (t=a,a=b,b=t)
19
20
21 invmat4(inverse,mat)
22 MAT4 inverse, mat;
23 {
24 MAT4 m4tmp;
25 register int i,j,k;
26 register double temp;
27
28 copymat4(m4tmp, mat);
29 /* set inverse to identity */
30 for (i = 0; i < 4; i++)
31 for (j = 0; j < 4; j++)
32 inverse[i][j] = i==j ? 1.0 : 0.0;
33
34 for(i = 0; i < 4; i++) {
35 /* Look for row with largest pivot and swap rows */
36 temp = FTINY; j = -1;
37 for(k = i; k < 4; k++)
38 if(ABS(m4tmp[k][i]) > temp) {
39 temp = ABS(m4tmp[k][i]);
40 j = k;
41 }
42 if(j == -1) /* No replacing row -> no inverse */
43 return(0);
44 if (j != i)
45 for(k = 0; k < 4; k++) {
46 SWAP(m4tmp[i][k],m4tmp[j][k],temp);
47 SWAP(inverse[i][k],inverse[j][k],temp);
48 }
49
50 temp = m4tmp[i][i];
51 for(k = 0; k < 4; k++) {
52 m4tmp[i][k] /= temp;
53 inverse[i][k] /= temp;
54 }
55 for(j = 0; j < 4; j++) {
56 if(j != i) {
57 temp = m4tmp[j][i];
58 for(k = 0; k < 4; k++) {
59 m4tmp[j][k] -= m4tmp[i][k]*temp;
60 inverse[j][k] -= inverse[i][k]*temp;
61 }
62 }
63 }
64 }
65 return(1);
66 }
