Revision: | 2.3 |
Committed: | Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg |
Content type: | text/plain |
Branch: | MAIN |
CVS Tags: | rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD |
Changes since 2.2: | +1 -56 lines |
Log Message: | Replaced inline copyright notice with #include "copyright.h" |
# | User | Rev | Content |
1 | greg | 2.1 | #ifndef lint |
2 | greg | 2.2 | static const char RCSid[] = "$Id$"; |
3 | greg | 2.1 | #endif |
4 | /* | ||
5 | * invmat4 - computes the inverse of mat into inverse. Returns 1 | ||
6 | * if there exists an inverse, 0 otherwise. It uses Gaussian Elimination | ||
7 | * method. | ||
8 | */ | ||
9 | |||
10 | greg | 2.3 | #include "copyright.h" |
11 | greg | 2.2 | |
12 | greg | 2.1 | #include "mat4.h" |
13 | |||
14 | |||
15 | #define ABS(x) ((x)>=0 ? (x) : -(x)) | ||
16 | |||
17 | #define SWAP(a,b,t) (t=a,a=b,b=t) | ||
18 | |||
19 | |||
20 | greg | 2.2 | int |
21 | invmat4(inverse, mat) | ||
22 | greg | 2.1 | MAT4 inverse, mat; |
23 | { | ||
24 | MAT4 m4tmp; | ||
25 | register int i,j,k; | ||
26 | register double temp; | ||
27 | |||
28 | copymat4(m4tmp, mat); | ||
29 | /* set inverse to identity */ | ||
30 | greg | 2.2 | setident4(inverse); |
31 | greg | 2.1 | |
32 | for(i = 0; i < 4; i++) { | ||
33 | /* Look for row with largest pivot and swap rows */ | ||
34 | temp = FTINY; j = -1; | ||
35 | for(k = i; k < 4; k++) | ||
36 | if(ABS(m4tmp[k][i]) > temp) { | ||
37 | temp = ABS(m4tmp[k][i]); | ||
38 | j = k; | ||
39 | } | ||
40 | if(j == -1) /* No replacing row -> no inverse */ | ||
41 | return(0); | ||
42 | if (j != i) | ||
43 | for(k = 0; k < 4; k++) { | ||
44 | SWAP(m4tmp[i][k],m4tmp[j][k],temp); | ||
45 | SWAP(inverse[i][k],inverse[j][k],temp); | ||
46 | } | ||
47 | |||
48 | temp = m4tmp[i][i]; | ||
49 | for(k = 0; k < 4; k++) { | ||
50 | m4tmp[i][k] /= temp; | ||
51 | inverse[i][k] /= temp; | ||
52 | } | ||
53 | for(j = 0; j < 4; j++) { | ||
54 | if(j != i) { | ||
55 | temp = m4tmp[j][i]; | ||
56 | for(k = 0; k < 4; k++) { | ||
57 | m4tmp[j][k] -= m4tmp[i][k]*temp; | ||
58 | inverse[j][k] -= inverse[i][k]*temp; | ||
59 | } | ||
60 | } | ||
61 | } | ||
62 | } | ||
63 | return(1); | ||
64 | } |
