1 |
/* RCSid $Id: interp2d.h,v 2.9 2013/02/15 19:15:16 greg Exp $ */ |
2 |
3 |
* Header for interpolation of anisotropic samples on 2-D plane. |
4 |
5 |
* G.Ward Feb 2013 |
6 |
7 |
8 |
#ifndef _RAD_INTERP2D_H_ |
9 |
#define _RAD_INTERP2D_H_ |
10 |
11 |
#ifdef __cplusplus |
12 |
extern "C" { |
13 |
#endif |
14 |
15 |
#define NI2DSMF 0.42f /* minimal smoothing factor */ |
16 |
17 |
#define NI2DIR (2*4) /* # interpolation directions */ |
18 |
#define NI2DIM 16 /* size of influence map */ |
19 |
20 |
/* Data structure for interpolant */ |
21 |
typedef struct { |
22 |
int ns; /* number of sample positions */ |
23 |
float dmin; /* minimum diameter (default=1) */ |
24 |
float smf; /* smoothing factor (def=NI2DSMF) */ |
25 |
float smin[2]; /* sample minima */ |
26 |
float smax[2]; /* sample maxima */ |
27 |
float grid2; /* grid diameter squared */ |
28 |
void *c_data; /* client data pointer */ |
29 |
struct interp2_samp { |
30 |
unsigned short dia[NI2DIR]; |
31 |
unsigned short infl[NI2DIM]; |
32 |
} *da; /* direction array (private) */ |
33 |
float spt[1][2]; /* sample positions (extends struct) */ |
34 |
} INTERP2; |
35 |
36 |
/* Allocate a new set of interpolation samples (caller assigns spt[] array) */ |
37 |
extern INTERP2 *interp2_alloc(int nsamps); |
38 |
39 |
/* Resize interpolation array (caller must assign any new values) */ |
40 |
extern INTERP2 *interp2_realloc(INTERP2 *ip, int nsamps); |
41 |
42 |
/* Set minimum distance under which samples will start to merge */ |
43 |
extern void interp2_spacing(INTERP2 *ip, double mind); |
44 |
45 |
/* Modify smoothing parameter by the given factor */ |
46 |
extern void interp2_smooth(INTERP2 *ip, double sf); |
47 |
48 |
/* Assign full set of normalized weights to interpolate the given location */ |
49 |
extern int interp2_weights(float wtv[], INTERP2 *ip, double x, double y); |
50 |
51 |
/* Get normalized weights and indexes for n best samples in descending order */ |
52 |
extern int interp2_topsamp(float wt[], int si[], const int n, |
53 |
54 |
/* Free interpolant */ |
55 |
extern void interp2_free(INTERP2 *ip); |
56 |
57 |
/* (Re)compute anisotropic basis function interpolant (normally automatic) */ |
58 |
extern int interp2_analyze(INTERP2 *ip); |
59 |
60 |
/* Compute unnormalized weight for a position relative to a sample */ |
61 |
double interp2_wti(INTERP2 *ip, const int i, double x, double y); |
62 |
63 |
64 |
* Typical use is to allocate an INTERP2 struct and assign the |
65 |
* spt[] array with the ordered sample locations in x & y. (The |
66 |
* actual orientation of the axes is not important so long as |
67 |
* the application is consistent.) During interpolation, either |
68 |
* interp2_weights() is called to obtain a normalized weighting |
69 |
* vector for all the samples, or interp2_topsamp() is called to |
70 |
* get the most important N samples for the specified location. |
71 |
* The weights (and indexes in the case of interp2_topsamp) |
72 |
* are then used as coefficients for corresponding sample |
73 |
* values in a vector sum that interpolates the function at |
74 |
* that location. |
75 |
* The minimum distance between sample positions defaults to 1.0. |
76 |
* Values spaced closer than this will be merged/averaged. |
77 |
* The interp2_spacing() call may be used to alter this distance, |
78 |
* causing the interpolant to be recalculated during the |
79 |
* next call to the sampling functions. |
80 |
* The default smoothing factor NI2DSMF provides near-optimal |
81 |
* interpolation when well-separated values are known |
82 |
* precisely. Increase this setting by a factor > 1 |
83 |
* with the interp2_smooth() call if greater mixing is desired. |
84 |
* A call of interp2_smooth(ip,0) resets to the minimum |
85 |
* default. It is not possible to "sharpen" the data. |
86 |
87 |
88 |
89 |
90 |
#endif |
91 |
#endif /* !_RAD_INTERP2D_H_ */ |
