root/radiance/ray/src/common/interp2d.h
Revision: 2.10
Committed: Sat Feb 13 16:49:18 2021 UTC (4 years, 3 months ago) by greg
CVS Tags: rad5R4, HEAD
feat: added client data pointer for caller convenience
1 /* RCSid $Id: interp2d.h,v 2.9 2013/02/15 19:15:16 greg Exp $ */
2 /*
3 * Header for interpolation of anisotropic samples on 2-D plane.
4 *
5 * G.Ward Feb 2013
6 */
7
8 #ifndef _RAD_INTERP2D_H_
9 #define _RAD_INTERP2D_H_
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 #define NI2DSMF 0.42f /* minimal smoothing factor */
16
17 #define NI2DIR (2*4) /* # interpolation directions */
18 #define NI2DIM 16 /* size of influence map */
19
20 /* Data structure for interpolant */
21 typedef struct {
22 int ns; /* number of sample positions */
23 float dmin; /* minimum diameter (default=1) */
24 float smf; /* smoothing factor (def=NI2DSMF) */
25 float smin[2]; /* sample minima */
26 float smax[2]; /* sample maxima */
27 float grid2; /* grid diameter squared */
28 void *c_data; /* client data pointer */
29 struct interp2_samp {
30 unsigned short dia[NI2DIR];
31 unsigned short infl[NI2DIM];
32 } *da; /* direction array (private) */
33 float spt[1][2]; /* sample positions (extends struct) */
34 } INTERP2;
35
36 /* Allocate a new set of interpolation samples (caller assigns spt[] array) */
37 extern INTERP2 *interp2_alloc(int nsamps);
38
39 /* Resize interpolation array (caller must assign any new values) */
40 extern INTERP2 *interp2_realloc(INTERP2 *ip, int nsamps);
41
42 /* Set minimum distance under which samples will start to merge */
43 extern void interp2_spacing(INTERP2 *ip, double mind);
44
45 /* Modify smoothing parameter by the given factor */
46 extern void interp2_smooth(INTERP2 *ip, double sf);
47
48 /* Assign full set of normalized weights to interpolate the given location */
49 extern int interp2_weights(float wtv[], INTERP2 *ip, double x, double y);
50
51 /* Get normalized weights and indexes for n best samples in descending order */
52 extern int interp2_topsamp(float wt[], int si[], const int n,
53 INTERP2 *ip, double x, double y);
54 /* Free interpolant */
55 extern void interp2_free(INTERP2 *ip);
56
57 /* (Re)compute anisotropic basis function interpolant (normally automatic) */
58 extern int interp2_analyze(INTERP2 *ip);
59
60 /* Compute unnormalized weight for a position relative to a sample */
61 double interp2_wti(INTERP2 *ip, const int i, double x, double y);
62
63 /***************************************************************
64 * Typical use is to allocate an INTERP2 struct and assign the
65 * spt[] array with the ordered sample locations in x & y. (The
66 * actual orientation of the axes is not important so long as
67 * the application is consistent.) During interpolation, either
68 * interp2_weights() is called to obtain a normalized weighting
69 * vector for all the samples, or interp2_topsamp() is called to
70 * get the most important N samples for the specified location.
71 * The weights (and indexes in the case of interp2_topsamp)
72 * are then used as coefficients for corresponding sample
73 * values in a vector sum that interpolates the function at
74 * that location.
75 * The minimum distance between sample positions defaults to 1.0.
76 * Values spaced closer than this will be merged/averaged.
77 * The interp2_spacing() call may be used to alter this distance,
78 * causing the interpolant to be recalculated during the
79 * next call to the sampling functions.
80 * The default smoothing factor NI2DSMF provides near-optimal
81 * interpolation when well-separated values are known
82 * precisely. Increase this setting by a factor > 1
83 * with the interp2_smooth() call if greater mixing is desired.
84 * A call of interp2_smooth(ip,0) resets to the minimum
85 * default. It is not possible to "sharpen" the data.
86 **************************************************************/
87
88 #ifdef __cplusplus
89 }
90 #endif
91 #endif /* !_RAD_INTERP2D_H_ */
