--- ray/src/common/interp2d.h 2013/02/09 00:55:40 2.1 +++ ray/src/common/interp2d.h 2021/02/13 16:49:18 2.10 @@ -1,32 +1,91 @@ -/* RCSid $Id: interp2d.h,v 2.1 2013/02/09 00:55:40 greg Exp $ */ +/* RCSid $Id: interp2d.h,v 2.10 2021/02/13 16:49:18 greg Exp $ */ /* - * Header for interpolation of anisotropic values on 2-D plane. + * Header for interpolation of anisotropic samples on 2-D plane. * * G.Ward Feb 2013 */ -#define NI2DSMF 0.42f /* minimal smoothing radius */ +#ifndef _RAD_INTERP2D_H_ +#define _RAD_INTERP2D_H_ +#ifdef __cplusplus +extern "C" { +#endif + +#define NI2DSMF 0.42f /* minimal smoothing factor */ + #define NI2DIR (2*4) /* # interpolation directions */ +#define NI2DIM 16 /* size of influence map */ /* Data structure for interpolant */ typedef struct { int ns; /* number of sample positions */ - float rmin; /* minimum valid radius (default=.5) */ + float dmin; /* minimum diameter (default=1) */ float smf; /* smoothing factor (def=NI2DSMF) */ - unsigned short (*ra)[NI2DIR]; /* anisotropic radii (private) */ + float smin[2]; /* sample minima */ + float smax[2]; /* sample maxima */ + float grid2; /* grid diameter squared */ + void *c_data; /* client data pointer */ + struct interp2_samp { + unsigned short dia[NI2DIR]; + unsigned short infl[NI2DIM]; + } *da; /* direction array (private) */ float spt[1][2]; /* sample positions (extends struct) */ } INTERP2; /* Allocate a new set of interpolation samples (caller assigns spt[] array) */ extern INTERP2 *interp2_alloc(int nsamps); +/* Resize interpolation array (caller must assign any new values) */ +extern INTERP2 *interp2_realloc(INTERP2 *ip, int nsamps); + +/* Set minimum distance under which samples will start to merge */ +extern void interp2_spacing(INTERP2 *ip, double mind); + +/* Modify smoothing parameter by the given factor */ +extern void interp2_smooth(INTERP2 *ip, double sf); + /* Assign full set of normalized weights to interpolate the given location */ extern int interp2_weights(float wtv[], INTERP2 *ip, double x, double y); /* Get normalized weights and indexes for n best samples in descending order */ extern int interp2_topsamp(float wt[], int si[], const int n, INTERP2 *ip, double x, double y); - /* Free interpolant */ extern void interp2_free(INTERP2 *ip); + +/* (Re)compute anisotropic basis function interpolant (normally automatic) */ +extern int interp2_analyze(INTERP2 *ip); + +/* Compute unnormalized weight for a position relative to a sample */ +double interp2_wti(INTERP2 *ip, const int i, double x, double y); + +/*************************************************************** + * Typical use is to allocate an INTERP2 struct and assign the + * spt[] array with the ordered sample locations in x & y. (The + * actual orientation of the axes is not important so long as + * the application is consistent.) During interpolation, either + * interp2_weights() is called to obtain a normalized weighting + * vector for all the samples, or interp2_topsamp() is called to + * get the most important N samples for the specified location. + * The weights (and indexes in the case of interp2_topsamp) + * are then used as coefficients for corresponding sample + * values in a vector sum that interpolates the function at + * that location. + * The minimum distance between sample positions defaults to 1.0. + * Values spaced closer than this will be merged/averaged. + * The interp2_spacing() call may be used to alter this distance, + * causing the interpolant to be recalculated during the + * next call to the sampling functions. + * The default smoothing factor NI2DSMF provides near-optimal + * interpolation when well-separated values are known + * precisely. Increase this setting by a factor > 1 + * with the interp2_smooth() call if greater mixing is desired. + * A call of interp2_smooth(ip,0) resets to the minimum + * default. It is not possible to "sharpen" the data. + **************************************************************/ + +#ifdef __cplusplus +} +#endif +#endif /* !_RAD_INTERP2D_H_ */
