root/radiance/ray/src/common/interp2d.h
Revision: 2.9
Committed: Fri Feb 15 19:15:16 2013 UTC (12 years, 3 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3
Changed from blkflg to influence flag array
1 /* RCSid $Id: interp2d.h,v 2.8 2013/02/15 01:26:47 greg Exp $ */
2 /*
3 * Header for interpolation of anisotropic samples on 2-D plane.
4 *
5 * G.Ward Feb 2013
6 */
7
8 #ifndef _RAD_INTERP2D_H_
9 #define _RAD_INTERP2D_H_
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 #define NI2DSMF 0.42f /* minimal smoothing factor */
16
17 #define NI2DIR (2*4) /* # interpolation directions */
18 #define NI2DIM 16 /* size of influence map */
19
20 /* Data structure for interpolant */
21 typedef struct {
22 int ns; /* number of sample positions */
23 float dmin; /* minimum diameter (default=1) */
24 float smf; /* smoothing factor (def=NI2DSMF) */
25 float smin[2]; /* sample minima */
26 float smax[2]; /* sample maxima */
27 float grid2; /* grid diameter squared */
28 struct interp2_samp {
29 unsigned short dia[NI2DIR];
30 unsigned short infl[NI2DIM];
31 } *da; /* direction array (private) */
32 float spt[1][2]; /* sample positions (extends struct) */
33 } INTERP2;
34
35 /* Allocate a new set of interpolation samples (caller assigns spt[] array) */
36 extern INTERP2 *interp2_alloc(int nsamps);
37
38 /* Resize interpolation array (caller must assign any new values) */
39 extern INTERP2 *interp2_realloc(INTERP2 *ip, int nsamps);
40
41 /* Set minimum distance under which samples will start to merge */
42 extern void interp2_spacing(INTERP2 *ip, double mind);
43
44 /* Modify smoothing parameter by the given factor */
45 extern void interp2_smooth(INTERP2 *ip, double sf);
46
47 /* Assign full set of normalized weights to interpolate the given location */
48 extern int interp2_weights(float wtv[], INTERP2 *ip, double x, double y);
49
50 /* Get normalized weights and indexes for n best samples in descending order */
51 extern int interp2_topsamp(float wt[], int si[], const int n,
52 INTERP2 *ip, double x, double y);
53 /* Free interpolant */
54 extern void interp2_free(INTERP2 *ip);
55
56 /* (Re)compute anisotropic basis function interpolant (normally automatic) */
57 extern int interp2_analyze(INTERP2 *ip);
58
59 /* Compute unnormalized weight for a position relative to a sample */
60 double interp2_wti(INTERP2 *ip, const int i, double x, double y);
61
62 /***************************************************************
63 * Typical use is to allocate an INTERP2 struct and assign the
64 * spt[] array with the ordered sample locations in x & y. (The
65 * actual orientation of the axes is not important so long as
66 * the application is consistent.) During interpolation, either
67 * interp2_weights() is called to obtain a normalized weighting
68 * vector for all the samples, or interp2_topsamp() is called to
69 * get the most important N samples for the specified location.
70 * The weights (and indexes in the case of interp2_topsamp)
71 * are then used as coefficients for corresponding sample
72 * values in a vector sum that interpolates the function at
73 * that location.
74 * The minimum distance between sample positions defaults to 1.0.
75 * Values spaced closer than this will be merged/averaged.
76 * The interp2_spacing() call may be used to alter this distance,
77 * causing the interpolant to be recalculated during the
78 * next call to the sampling functions.
79 * The default smoothing factor NI2DSMF provides near-optimal
80 * interpolation when well-separated values are known
81 * precisely. Increase this setting by a factor > 1
82 * with the interp2_smooth() call if greater mixing is desired.
83 * A call of interp2_smooth(ip,0) resets to the minimum
84 * default. It is not possible to "sharpen" the data.
85 **************************************************************/
86
87 #ifdef __cplusplus
88 }
89 #endif
90 #endif /* !_RAD_INTERP2D_H_ */
