root/radiance/ray/src/common/interp2d.h
Fri Feb 15 19:15:16 2013 UTC (12 years, 2 months ago) by greg
Changed from blkflg to influence flag array
Fri Feb 15 01:26:47 2013 UTC (12 years, 2 months ago) by greg
Additional tweaks -- now 11 times faster than original version
Thu Feb 14 19:57:10 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.6: +12 -2 lines
Doubled calculation speed and exposed raw weight computation
Tue Feb 12 00:18:28 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.5: +9 -9 lines
Minor comment change
Mon Feb 11 23:33:35 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.4: +20 -13 lines
Added accessor functions for minimum spacing and smoothing parameters
Mon Feb 11 22:56:22 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.3: +29 -5 lines
Changed radius specification to diameter and added usage comment
Sat Feb 9 20:56:40 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.2: +13 -1 lines
Added missing #define's for C++ and duplicate headers
Sat Feb 9 17:39:21 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.1: +7 -2 lines
Diff to previous 2.1
Added interp2_realloc() call, exposed interp2_analyze() and code improvements
Sat Feb 9 00:55:40 2013 UTC (12 years, 2 months ago) by greg
Created routines for interpolating anisotropic 2-D samples
