root/radiance/ray/src/common/interp2d.h
Revision: 2.1
Committed: Sat Feb 9 00:55:40 2013 UTC (12 years, 4 months ago) by greg
Created routines for interpolating anisotropic 2-D samples
1 /* RCSid $Id$ */
2 /*
3 * Header for interpolation of anisotropic values on 2-D plane.
4 *
5 * G.Ward Feb 2013
6 */
7
8 #define NI2DSMF 0.42f /* minimal smoothing radius */
9
10 #define NI2DIR (2*4) /* # interpolation directions */
11
12 /* Data structure for interpolant */
13 typedef struct {
14 int ns; /* number of sample positions */
15 float rmin; /* minimum valid radius (default=.5) */
16 float smf; /* smoothing factor (def=NI2DSMF) */
17 unsigned short (*ra)[NI2DIR]; /* anisotropic radii (private) */
18 float spt[1][2]; /* sample positions (extends struct) */
19 } INTERP2;
20
21 /* Allocate a new set of interpolation samples (caller assigns spt[] array) */
22 extern INTERP2 *interp2_alloc(int nsamps);
23
24 /* Assign full set of normalized weights to interpolate the given location */
25 extern int interp2_weights(float wtv[], INTERP2 *ip, double x, double y);
26
27 /* Get normalized weights and indexes for n best samples in descending order */
28 extern int interp2_topsamp(float wt[], int si[], const int n,
29 INTERP2 *ip, double x, double y);
30
31 /* Free interpolant */
32 extern void interp2_free(INTERP2 *ip);
