root/radiance/ray/src/common/interp2d.h
Revision: 2.3
Committed: Sat Feb 9 20:56:40 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.2: +13 -1 lines
Added missing #define's for C++ and duplicate headers
1 /* RCSid $Id: interp2d.h,v 2.2 2013/02/09 17:39:21 greg Exp $ */
2 /*
3 * Header for interpolation of anisotropic values on 2-D plane.
4 *
5 * G.Ward Feb 2013
6 */
7
8 #ifndef _RAD_INTERP2D_H_
9 #define _RAD_INTERP2D_H_
10
11 #ifdef __cplusplus
12 extern "C" {
13 #endif
14
15 #define NI2DSMF 0.42f /* minimal smoothing radius */
16
17 #define NI2DIR (2*4) /* # interpolation directions */
18
19 /* Data structure for interpolant */
20 typedef struct {
21 int ns; /* number of sample positions */
22 float rmin; /* minimum valid radius (default=.5) */
23 float smf; /* smoothing factor (def=NI2DSMF) */
24 unsigned short (*ra)[NI2DIR]; /* anisotropic radii (private) */
25 float spt[1][2]; /* sample positions (extends struct) */
26 } INTERP2;
27
28 /* Allocate a new set of interpolation samples (caller assigns spt[] array) */
29 extern INTERP2 *interp2_alloc(int nsamps);
30
31 /* Resize interpolation array (caller must assign any new values) */
32 extern INTERP2 *interp2_realloc(INTERP2 *ip, int nsamps);
33
34 /* Assign full set of normalized weights to interpolate the given location */
35 extern int interp2_weights(float wtv[], INTERP2 *ip, double x, double y);
36
37 /* Get normalized weights and indexes for n best samples in descending order */
38 extern int interp2_topsamp(float wt[], int si[], const int n,
39 INTERP2 *ip, double x, double y);
40 /* Free interpolant */
41 extern void interp2_free(INTERP2 *ip);
42
43 /* (Re)compute anisotropic basis function interpolant (normally automatic) */
44 extern int interp2_analyze(INTERP2 *ip);
45
46 #ifdef __cplusplus
47 }
48 #endif
49 #endif /* !_RAD_INTERP2D_H_ */
